thought id share my project R33 GTR
after buying the car in early 2007 i wasnt happy with the orginal paint work so i stripped the car to a rolling bare shell so all glass, panels, interior was removed and the car was resprayed inside and out in the orginal R33 GTR Silver. Then was the process of putting the car all back together and new window seals/mouldings were fitted.
After having the car on the road for around a month the engine died (cracked a piston and scored the block) so we rebuilt it
off the top of my head this is what has been done
HKS Drag Coilovers
HKS GT-SS twin turbo Kit
HKS Twin Power ignition
HKS intercooler piping
Greedy suction kit
Greedy fuel rail
Sard 800cc injectors
Sard fuel pressure reg
Trust air filters
Trust 100mm intercooler
Trust front pipes
Trust dump pipes
kakimoto Exhaust
Apexi exhaust valve
Apexi D-jectro Power FC
Apexi boost controll kit
Alloy Radiator
block has been bored out to 40 thou
regrind crank
ACL Forged Pistons
ACL conrod bearings
ACL main bearings
ARP Conrod bolts
Tomei 1.2mm headgasket
Tomei metal inlet gaskets
Tomei metal exhaust gaskets
Tomei oil restrictor
Tomei Sump Baffles
Tomei poncams 9.15mm lift 260 drg duration
Tomei Adjustable cam gears
Tomei type A valve springs
Tomei fuel pump
new Genuine Nissan seals, gaskets etc
new genuine Nissan valve stem seals
N1 Water pump
N1 oil pump
custom oil catch can/washer bottle
Nismo GMAX II twin plate clutch
Nismo 320 speedo and matching centre gauges
Nismo LM GT4 Black 18" Wheels
Nismo clear front and side indicators
Brembo calipers repainted in silver
Cusco Strut brace
brand new Xenon headlights
nismo carbon fibre pillar garnish
GTR carbon fibre spoiler caps
carbon fibre cooling panel
carbon fibre wing blade
pioneer dvd player
DLS front and rear speakers
also the cylinder head has had some work including, machining and reconditoned with new valve stem seals etc etc
yet to fit
R34 GTR Interior
rear pods
Gannador mirrors
more pics to come
Edited by Nisswreck
  • 9 months later...
now has a carbon bonnet and smoked indicators, gannador mirrors and carbon exhaust shield coming next week
Nice car mate quick question what bonnet is that?? been looking for something similar for my 33gtr
  • 2 years later...
very over due update!
its now making 363 kw at the wheels and 860 n.m of torque on 17 psi and E85 Fuel
also now fitted with 19x10.5 TE37 SL's, tomei headlight duct, Titanium drag exhaust and a origin GT wing for track use
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
