  • Replies 187
Posted Images
Zennon, thats an awesome picture! Bit dark though, but thats just my opinion.
Yeah think you're right actually - it looked fine at home but then when I saw it on my work pc is was like :)
(then realised it was because I had played with my gamma and brightness at home so i can see the bloody counter strike campers :) )
OT
what do you think of the innov8? im tossing up that or an ultra touch.. my nokia N85 is rubbish never again!
the innov8 was barely sold here. Mine was bought overseas from ebay. Very hard to find one here and hence running overseas firmware (couldnt find australian firmaware) It doesnt affect the functionality of the phone but.
Depends what you are after on a phone.
The innov8 has wifi and runs on symbian OS (same operating system as the new gen nokia's, so there are many applications you can run. After you crack the phone there are a lot of apps to download. Ive got about 3 different GPS programs and 2 different office suite apps) also has 8gb or 16gb internal memory.
Also the middle button on the innov8 is infra-red sensor, so you slide your thumb over it to move the cursor when browsing websites etc. Think of it as a mini touch pad on laptops. Although its much more sensitive as its a small pad.
Quickly reading about the ultra touch, they are touch screen but dont have wifi or big internal memory. however they are very small phone.
sweet ill go grab a 16gb one then, my only prob with internal mem phones is if you drop it in water you cant easily remove the mem card to download your data, just means more frequent backuping....
The i8510 does have a memory card slot, so you can get a 8gb internal and then buy a 8gb card if you want.
first attempt at some panning shots.. lots of practice needed... and a decent lens for it, was using the 50mm for these ones. I think.. might have been the stock lens too..
what noticable difference does the lens make when panning?
yeah I know you can do it with any lens, but with the 50mm it was hard to get the whole car in focus, it usually focused on the rear or the door or the front but not the whole thing
don't use it wide open then?
he was using f22.
i dont think you did to bad considering they were taken at 1/40th of a second. maybe start at 100th and work your way down from there. although im no pro so take that with a grain of salt.
Edited by Jay019
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
