I am gonna be looking at this dr30 skyline on tuesday. Guy wants 9.5 with no compliance and 10.5 k complied and reg.
The paint looks pretty good but the engine looks like its done 250,000kms plus.
What do you guys think? How much would you pay?
Only thing is i don't wanna not buy it only to find that i cant find another dr30 coupe for like a year or something, i know these are fairly rare now.
Cheers.
https://www.sau.com.au/forums/topic/281638-how-much-would-you-pay/
You're right, there are fewer of these every year, but in saying that, how much are you willing to pay to have something that you really want? Are you prepared to pay for the troubles and associated costs that a nostalgic vehicle like this brings?
Buy this and you'll probably wonder why you did when the repair bills start to come in. But if you really want it, buy it. The answer to the question lies with you alone. Many people will call you mad, and the rest will say that it's a cool car because of the rarity. Who knows, in a the years to come they may be up there with the KPGC10.
Personally I wouldn't do it, but as I said, it depends on how much YOU want it.
Good luck with it though man.
I guess I really just have to have a good look at it. I was just wondering what people thought of the car i guess, if the price is around what it should be for one of these. I have done some searching but people seem to bring up figures like 5-7k max so i'm a little unsure how much its worth.
But yeah your right, as soon as stuff starts going wrong i'll more then likely regret buying it, especially since fj20's are gonna be hard to get parts for.
Not old enough to be a classic, not new enough to be fast. that's my opinion on the matter. (im' not a fan of that blue either)
Of course, if your buying it your buying it because its a model of skyline you like, so you probably won't be dissapionted by the result.
Edited by sneakey pete
that looks more trouble than its worth to be honest , i noticed uneven gap around door not shuting ok , might just need adjustment but it might been smashed and then done in blue.
engine looks bad but i guess with but cleanup would be looking mint but what about wear and tear.
as R31Nismoid check with importers and you will be better off.
on another note its your cash and if you want to get that car then go for it we are just stating the obvious and our opinions
cheers
To import one it'll cost around 4-6k to it, then just ad the shipping, stamp duty and compliance so around the same price anyways.
Mad082: If you could let your mate no someone is interested in buying it maybe he'll think of selling :devil: , for the right price ofcourse. I don't mind paying the dough just as long as its a good example of one.
seems everyone selling an old nissan/datsun these days is jumping on the expensive bandwagon :D
These are getting rare, and the front on this is even rarer (iron face, or something they call it?)
If you were going to restore and sit on it for a while, might be worth it as a future collectible, but it'd be a fair gamble
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
