Hi all,
I would like to completely remove the HICAS system in my R34 GT-R (instead of just a cancel rod etc etc) because of the weight saving (20kg's?) and the benefits in handling but am curious to know the procedure for R34 GT-R's... I have read the threads which describe the R32/R33's but its not a complete removal... just cancel rods and not on an R34 GT-R...
Im guessing that it would be pretty much the same, (Ie - remove the rear steering arm, fluid resuviour tank/lines & motor in the boot) but I am interested to know of other R34 GT-R owners who have done this before...
Cheers,
Edited by xanavinismo
https://www.sau.com.au/forums/topic/281675-complete-r34-gt-r-hicas-removal/
umm its not the same as a 32 at all as it's not a hydraulic system. there are no lines to the front of the car or solenoid in the engine bay to worry about. the resoviour in the boot is for attessa not hicas.
as for the actual hicas rack - the lock washer option locks the standard rack in place, or you can get a hicas lock bar to replace the standard motor. If you really want to remove it altogether you would need to convert it to an s13 style setup with tie rods instead of a hicas rack....there is some information of how we did this in our racecar in the Builds section
Thanks for your info duncan. So the hicas motor does weigh a fare bit? Also, does that mean I wouldnt have the problem of having the HICAS light coming on because there is no solenoid in the engine bay?
Cheers,
Glen
I found these Midori Hicas Cancellers... it looks like it will save a heap load of weight!
Link: http://www.midoriseibi.co.jp/tuning/others...-canceller.html
Also appears that they bolt up to the standard mounts where the Hicas normally goes with no bar in between what so ever. Although more expensive than a 'Cancel Rod' these seem like the closest thing to complete removal of Hicas without much fuss!
However, has anyone ever used these?
yeah, but the brace doesnt get rid of the hicas unit itself so no real weight reduction.
just googling 'midori hicas canceller', there seems to be somewhat of a review on the product: http://minkara.carview.co.jp/userid/424045...0193/parts.aspx
not much info, but its got a pic and looks like what you're after.
  • 5 years later...
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
