  • Replies 45
That's what you call good quality safety gear! But that can't be me, because I notice he remembered to put on his safety goggles where as I would have conveniently left them on top of the car and forgotten them. But that's another emergency room story.
The real problem is that now I'm in Melbourne it's damn cold (that's saying a lot as I work in shorts year round in Sydney) and I've had to start wearing pants when working my usual late night last minute jobs. So of course I'm welding and instead of dropping a little spot of weld on to my bare skin and causing a small little burn that's fixed with a lot of expletives, it instead gets logged in my coveralls, catches fire and before I notice it I've got a 2 inch round section of burnt polyester embedded in my skin!
I really should be working for ACCC in their product safety section, defining common sense safety practices, but again that's a whole other story...
Gary,
is there anything that can be done to fix this...
But the standard rear geometry in an R32 is not the best. The anti squat built into the lower control arm pivot points for example. Nisan recognised this, that's why R33's and R34 have far superior rear geometry
And also what can be done to fix the front, or do you jsut need to keep replacing the bushes?
I really dont want to change to a 34 to fix these issues
Thanks mate
Duncan covered the rear quite well. For the front I simply redrill the holes in the brackets for the upper control arm inner pivot to remove the twist. From memory the rear hole needs to be further down, lower in the bracket, by around 15 mm. To work out where to redrill the hole I do a dummy assembly (no spring or shock installed and at the correct ride height) and then put the front bolt into the upper control arm via the standard hole. Then it's obvious where the rear hole needs to be drilled.
Cheers
Gary
  • 12 years later...
On 8/13/2009 at 8:35 AM, djr81 said:
Here are a couple of drawings and three photos.
The first shows what Nismo do to the standard upper link bracket to allow for more castor/camber. Essentially it is a stock component but with the holes drilled differently - the front moved closer to the centreline of the car & the rear lower. Thus the upper link is rotated on two axes - allowing for more castor.
The second shows a stock LHS bracket.
The third shows the Nismo bracket installed with a stock upper arm. Interestingly (or not) the bracket ends up giving you less camber for the same arm length. The shot was taken before I installed some new arms that I had made.
The fourth is a drawing of a Cusco arm - these are 10mm shorter than the stock arms. Note the trail. Unfortunately I don't have a drawing of a stock arm. Mostly due to being lazy.
The last shows the whole lot bolted up with the new arm - in rattle pack black, no less. I drew the arms to use the Whiteline bushes.
As an aside note that Nismo used to do a sliding bracket for the R32, but now all you get is a stock item with harder bushes. Also their castor rods are approx 5mm shorter than the stock items.
Just for posterity I believe there to be an error in the location of the NIsmo bolt hole in the first drawing.
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
