  • Replies 104
Posted Images
There are always good and bad stories about every workshop... I am sure that RP071 has a true story to tell but one experience for one person doesnt mean that it will happen to everyone.
I know these guys quite well as they are a customer of mine and they seem to know what they are doing.. They have built some very serious cars.
1. Bullet32 - Show 'n' Shine
2. Kat - Dyno comp and Show 'n' Shine
3. Bluprint - Show 'n' Shine
4. Ex!$t3nZ - Show 'n' Shine (ill be coming but my car will probably be parked with the toymods people)
Edited by Ex!$t3nZ
Too true, I've heard some horror stories about Gas motorsport as well, but I'll leave that for another day.....
PM sent to everyone that was asking questions. Basically, I have told them that it is up to them wether they run their cars and all I have done is to share my experience.
was told there should be heaps of Evos and WRX
Awesome! The 4wd category should be entertaining then :rofl: I got my car back on friday, its cutting sick but unfortunatly its 2wd for the moment. It should be sorted for the day so im in!
Only the dyno comp though, my car still looks like sh1t.
Edited by noakespg
Whatcha putting out at the rears now matey? Haha occasionally I do something silly like activate rwd mode and it makes for interesting driving :D
Kat should put all the Evo/WRX's to shame, even with small turbo's. Now the Supra is another matter.
"Kat's small turbos" I know that appears to be your favourite thing to say. Just pointing out they aren't a whole lot smaller than yours. It's only turbos I'm talking about here :rofl:
I'll be in! I spose it will be stupidly early though *sigh* :)
5. Shell - Show 'n' Shine
Small turbs are underated. I personally know of a dyno proven 505awkw made with 'little' 2530's. I like Kat's pair. They look great, the bang for the buck is there, she's got the runs on the board,... We're still talking turbos, aren't we?!? ; p
anyhoo, I'll be there with a different kind of JDM model for the show'n'shine. Go the Foz!
that 505 wasn't on pump fuel :P
No, but does that matter? Does a sub 10 second run in a street registered car matter either? Or a bunch of show'n'shine trophies? Or magazine features?
No, it had twin, 'little' low mounts on. That's what matters.
Whatcha putting out at the rears now matey? Haha occasionally I do something silly like activate rwd mode and it makes for interesting driving :(
Ha! Got it back and it was pumping out just shy of 360kw atw. It lifted off the dyno the first run so we needed people in the boot.
The Autronic rocks.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
