  • Replies 104
Posted Images
T'was a good day, and SAU was represented well. At least I thought so. Some selfish douchebag took out the People's Choice Award, and it was of no suprise to anyone that a Supra won the dyno comp, although props to R34power's mate for doing so.
There was a lot of JDM goodness on display, as those that were there will attest to. I enjoyed it. How about everyone else?
yeah he was shocked there was suppose to be a wide body r32 blue that would have beaten him.
I thought that blue Supra might have taken the people's choice.
Bad timing for me. My car is currently not behaving itself and has a few issues that we weren't able to iron out before the day.
Would still like to have gone but our house settlement went through yesterday and unfortunately I had a busy day with that.
i thought you guys failed in your turn out compared to most other days. that said i only got their at 2 (Due to work). was hoping to see alot more skylines out. have a good one guys, stu
I reckon we went OK. For those that showed up at 8.30am, it's an ask to do a full day, yeah? By 1pm, it was starting to wind down, so I'd say you missed the best five hours when you were at work
Musta missed you Jayce :) Good to see R31Nismoid and Mark and Mick and Damo and others out...
I got there when that matt black 180 went on the dyno.
Me and Xmetal got some awesome shots last night too... had a full rig attached to the car, can't wait to see them!
Hi all
Great to see plenty of nice JDM cars on Saturday. Sorry I didn't put my car on, but I've pretty much made a decision that I won't be dynoing my car on any other dyno without one of the ESP boys to oversee the operators. I just don't want to risk any damage to my engine. Plus I don't think I would have beaten the 398 that Nathan put down in his Supra as I think my valve stem seals are on their way out.
I did mention to the guy that was looking after the shownshine that if they run this event again next year that they might consider doing it either 3 weeks before or after this particular date as a lot of owners could be in the middle of playing footy finals and they should also consider having it run on a Sunday as well.
I was a little disappointed with the FD turnout though, maybe they were all changing rotor seals that weekend.... :woot:
Anyways, good to see some nice Skylines there, fingers crossed this event gets bigger and better for us JDM owners.
Cheers
Ross
You see my company car there Shell?
Cheers, D
Hey guys,
I've uploaded my photo's to the net but I have some people who are interested in some of the photo's, so I can't post them up here straight away.
If your cluey enough, you could probably find the photos :).
I am obviously of the dumb so I'll just wait till you can post them here :)
Cheers, D
Maybe, what's your company car? Should I know this? lol
In and out as quick as i could... 3am sat arrive - 4am mon depart :)
Good to see/meet a few people in my 1hr outing at a car thingo last min notice haha
It being around the corner from my accommodation helped i must admit.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
