Hi guys,
Has anyone powder coated their R34 GTR rims and had the centre caps done as well?
I dropped my rims off tonight to get coated but they dont think they can do the centres due to them melting in the oven (200 degrees for 20min, i think) and dont want to waste one in the process just to try.
Any help would be great......
Cheers
NutR33
https://www.sau.com.au/forums/topic/282285-powder-coating-r34-gtr-rims/
some plastics can be coated, others cant .
IE -
ford falcon plastic tappet cover covers = yes -
ls1 inlet manifolds = yes
r34 plastic front cam gear covers warp in the heat
i should try it on the 33 gtst rim centres i have - but its a big risk on 34 GTR centres
Craved written on the back of an R34 GTR centre cap is
>PC+ABS<
SAE PC+ABS
I can take a pic if that will help.
N1GTR, last time i brought a centre cap it was about $80 trade price, part number 40315-AA310
Cheers
NutR33
>PC+ABS<
SAE PC+ABS
Cheers
NutR33
LEGEND!!! Cheers :)
>PC+ABS<
SAE PC+ABS
Cheers
NutR33
dude, thats exactly what i needed - cheers
the resins used in some PC/ABS blends seems to have a melt point of 260 degrees - suggests that coating them should not melt them at a lower cure temp of 180 degrees.
forgot to get the centre cap from the 33 gtst rims i have, if the makeup of those is the same then a test on those will let me know if they will survive.
if a photo can be taken of the back of it to display the re-inforcement setup of the caps, this will give a good impression of the likelyhood of shape change at these temps.
  • 4 weeks later...
gtst centres are PA6+PPE plastic - but they hold up fine under 180 degree coating temps
One i tested was filthy with old high temp matt black paint - once i find the clean pair that i didnt paint i'll start working out the coating process - thing to overcome with plastic is gas release from the plastic as the coating flows and links on the part
got mine powder coated in satin black (not quite glossy enough unless very clean and waxed) got the caps done as well. No problems at all
unless powder coater just sprayed the caps... not sure...
Edited by SS8_Gohan
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
