Fair enough. Text is hard to convey tone sometimes. I got a bit of a "Why don't you let the big boys get back to work" with a pat on the head kind of vibe.
I've got NFI about coilpacks / spark plugs whatever (which is also why I don't work on engines). I got the impression from the thread that the coilpacks and plugs in the RB are so close together that they're easy to mistake for a single unit, whereas he might be used to them being more separated (or cars with no coilpacks at all).
From the assumed knowledge in his questions it seemed like he just wasn't aware of how the RB specifically was engineered, not that he'd never pulled anything off any engine before. Every new car requires a bit of learning on how it all works and the easiest way is to associate it with things you already know.
But hey, its nice to see the tone go more civil here. It's amazing at how this "community" can mend its fences when everyone's on the same page, which is only possible when some people stop talking poo.
the best way i learnt about the RB was working on the engine itself, but not by myself to begin with. im lucky enough to have a tuner/mechanic that is willing to teach me when i want to know something, and is always happy to answer my quesions. it is quite easy to think that the spark plug/coilpack is a single unit, as you cant see the spark plug until you take the coilpack off it....
i guess everyone has there own way of looking into things and finding out info, i did some research on the RB while i was waiting for my car to come over from Japan, but the real learning process didnt start to happen until i got the car itself.
i can now pull things apart on my car and know i can put it all together back safely and not have any issues.
it all takes time tho :)
  • Replies 40
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
