Hello peoples how are we all ?
I am selling my skyline in this saturdays local rag
when all those buyers call me up interested I just want to know what has worked for you guys before in selling cars
as i have never sold a car before any hints or tips on how to spot or avoid the bullshitters who come around and want to test the car but not actually buy it
like should i get a copy of their licence before they drive it and if they crash am i covered for that time? (famous classic pfft) maybe a question i shuld ask them
but yeah any tips on selling points other than cleaning it and hoping the engine doesnt blow up??
priced at 19999
1995 Gtst R33 type M , Manual 76000
Mods
Apexi TT
Apexi Pod
Type 3 BOV
Boost Guage
boost at 10 psi
Apexi sticker across front window
should ir emove that or keep??
thanks guys
https://www.sau.com.au/forums/topic/28243-need-some-tips/
Some paranoia tips:
1)don't disclose your address too prematurely(dodgy theives posing as buyers)
2)Check that he has a valid license of course.
3)Never do the swap-over when it's his turn to test drive in a quiet place lest you get carjacked...
I guess you'll generally be able to gauge a person's 'real' interest by the questions he asks i guess...
Good luck with the sale!
https://www.sau.com.au/forums/topic/28243-need-some-tips/#findComment-587523
Personally I wouldnt let them drive it at all. Take them for a spin, if they want to feel the performance you do the trashing. Be smart, if someone who has never driven your car before gets behind the wheel and isnt used to the way it drives, handles and feels and they bin it, what are you going to do? End of the day, dont let them drive it.
https://www.sau.com.au/forums/topic/28243-need-some-tips/#findComment-587714
i had plenty of test drives and 4 of the guys that tested it didnt even want to flog it (suprising yeah) cos they werent sure on the power/handling
the final guy used to race in the UK etc and i have no doubt he can handle the car but he actually had respect for a nice car and didnt thrash it really.
if the dude is 17 and you can see his bright P plates then be cautious about the handing over the keys
also if they rock up in a beaten up bucket of crap go with them cos you really dont want to be left holding the keys of that while him and his mates roll away in your pride and joy (FOR FREE)
good luck mark
https://www.sau.com.au/forums/topic/28243-need-some-tips/#findComment-587778
I'd be cautious about handing over the keys if the potential buyer had mates with him/her. If theres more of them than you I wouldnt let them drive it. Just for the fear of a jacking.
But I guess if its just you and the buyer in the car this will be ok I guess.
Also, If you swap drivers be sure to remove the keys as well. Once you are in the car again and the potential buyer is in the drivers seat, THEN hand over the keys.
https://www.sau.com.au/forums/topic/28243-need-some-tips/#findComment-588303
I agree with rob77 and ReVN211, take them for a drive the first visit and only let them drive the second visit. I'd also ask they only bring one friend at most and 2 forms of ID. The ID you collect and leave in your home when you take them for a drive. Leaving the keys to their car seems to be popular with most buyers but it does nothing for me.
https://www.sau.com.au/forums/topic/28243-need-some-tips/#findComment-588883
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
