Now before anything, I don’t want to turbo my current block and I don’t want to sell my car and buy another and I want a 4WD car, so please don’t just clog this topic up with these suggestions.
I'm currently an owner of a 1995 R33 GTS4 Skyline and have got off my ‘P’ plates, now what I want to do is get more power from my car, after some research I want to get a turbo engine and do a swap. I also want to keep it fairly stock as it is an every day driver and don’t want to be blowing up stuff and spending heaps on fuel.
Now I have tracked down an RB25DET 4WD from a Stagea, but they haven’t got much…or any…history on it so I'm preparing myself that I may have to rebuild it.
So my questions are:
1. How much would it cost me to get someone to rebuild it? (take into account that I will give them the motor on a pallet)
2. Is there a workshop manual I can get that will take me through step by step on what to do (I'm a first year apprentice so I would like to do the work myself)
3. What else will I need for the conversion? This is the list I have so far (let me know if I don’t need items as well):
Turbo engine loom
Turbo gearbox loom?
Turbo ECU
Front and rear hubs (5 stud)
Front and rear brakes
Master cylinder and booster
Intercooler and pipes
Exhaust
Fuel pump
Clutch?
If I can get enough information on this I will be doing it and am happy to make a ‘How To’ diary on it!
So please if you can help me out I would really appreciate it!
Cheers!
No my car is manual, is this only applicable for autos?!?
Also the motor im looking at is auto so i will be swapping out the auto front dif one for my current manual one so the gearing ratios are the same.
if memory serves me correct the N/A gearbox is nowhere near the strength, gotta question drive shaft and so on as well.
Not a cheap conversion for the end result that's for sure.
You planning on changing brakes? (do they come 5-stud in R33?)
I don't think you need a gearbox loom because i believe the gearbox loom is for auto's thus letting the ecu shift it up/down.
It certainly won't be a cheap conversion that's for sure. Everything else looks spot on as far as parts go. Have the engine checked you may save 6grand (minimum) if you don't need a rebuild as you said it's a daily and the rb25s aren't weak so they won't stuff up easily
I don't know what sort of parallels there are mechanically and electrically between a 4WD NA R33 and the same era Stagea but it is worth researching and keeping an eye out for wrecked Stags in that era - donor car sort of idea .
If a donor car has everything you need to build an AWD R33 25DET then it's possibly the cheapest way of getting the bits AND it'd be a matching set from a car you can order spares for . Stags of that era may not get you four piston calipers or the discs that suit them but I believe they bolt up anyway .
Something to know early is does your R33's era Stag have a manual transmission option .
Also importantly double check the diff ratios because those for an NA R33 RB20 probably won't suit the power characteristics of an RB25DET . I think the final drive choices were 4.111 and 4.4ish .
Long shot idea but worth a few searches , cheers Adrian .
Also for kicks search prices for 33 GTR with blown engine - who knows ...
Edited by discopotato03
I've done this conversion in a 32 GTS4. I used an aftermarket ECU (Wolf 3D 4+). The engine itself drops straight in, and bolts up to everything - gearbox, driveshafts, P/S pump, A/C compressor.
The outright majority of Stagea engines are autos - manuals are almost rare as chicken teeth. So you will need a new flywheel, and a new spiggot bearing.
The diffs in a Stagea are 4.08:1 . RB25DET doesn't need 4.375 final drive, so I ended up getting a Stagea rear diff and swapping the crown wheel and pinion over to the R32 diff housing. Also, I don't think the Stageas have any form of LSD rear, so another reason to swap the gears.
He will want a GTR box
Drive line in the GTS4 is GTR so it will hold...and yes ill be doing brakes though the front hubs have to be from a GTR the calipers will be GTST
You will want GTR brakes and driveline, GTS4 stuff is weaker, get under and measure! Best way to check.
You could get a series 2 Stagea(so a NEO motor, which has GTR rods standard), try and find a manual half cut. But personally i think the cheapest option would be to grab the series 1 stagea motor(similar to the series 2 R33 but rumored to be different cams) and sort out a GTR box, then replace driveline parts as you break them :banana:
Im pritty sure the drive line is GTR, i had it on a hoist the other day and it was massive, though i havent seen a gtr drive line i know mine is bigger than a new BMW M5's. If some one can tell me the diamiter of a gtr tail shaft then i can check it out.
Also what tests can i do to see if the motor im looking at is ok?
your doing what I'm doing! lol, my cars going in in a couple weeks, I picked up a stagea motor and whole front cradle took it all to my mechanic he told me its pretty much a straight bolt on swap and quoted me $500-$700 labour. Your standard GTS4 box will hold no worries (as the previous owner of the stagea motor had it in his r33 gts4 with standard box and had no probs), but suiting your needs as a daily driver don't worry about a GTR box and drive shafts unless your gonna chase some big power in the future. It will hold.
Keep in mind only 5stud hubs from a GTR or stagea will fit in the front, the brake lines were a bit different as well, i had to get mine modded a little bit, everything else is pretty much straight forward.
PS. I got a spare pair of front R33 GTR front hubs for sale if interested :down:
My GTS-4 has a Stagea RB25DET (series 1 type) and supposedly has a Stagea manual too (at least the receipt says) which is what I've been trying to work out whether I actually do have a Stag box and all the ATTESSA hardware or whether its just a standard GTS-4 box (was thinking this in regards to trying to find a Series 1 RB25DET ECU to replace the Microtech fitted).
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
