  • Replies 114
  • 2 months later...
Well im back at it again,After power cruise this year and the car being down on power and not performing like it should.......it soon come to pass that my rb26 had packed it in and thrown a ring lan in No 6.
SOOOOOOO like normal i can t just take the easy road i have gone out and bought some new goodies for my gtr.
Nur spec 34 gtr rb26 with head work done by prime in japan!
Jun oil pump
N1 water pump
6 pot greddy front brakes
6 boost manifold twin scroll
264 hks cams 10.01/10.08 lift
Greddy twin pipe
turbosmart 45mm gate
And im currently looking at one of the new billet range of turbonetics turbos...............
Pictures to come as always i have some but not all.
I know its been while but after you cactus your motor you do not even want to open the door to the shed.......
Watch this space!!
Edited by Gtir-keiron
they always used to "fail" under race situations. not sure if these are a new breed or not but the tuner i use is a TS agent and he wont use there waste gates as he has seen to many fail.
Tial stuff is cheap as out of the states at the moment as well. and ive never read a bad thing about them.
im sure it will be fine im just not a fan.
  • 2 months later...
So to be on the safe side i had my 34 nur motor pulled down and crank checked due to the fact the car it came out of had been side swiped.
Turns out the crank was bent
So i have ordered a new crank
cp pistons manly rods
arp headbolts
acl bearing kit
new gasket kit
turbonetics gtk billet 750 split pulse rear.
Hope to have this all in and tuned running for power cruise this year
hoping for 550 to 650 hp at all 4 wheels on pump but we will see how that goes.
  • 4 months later...
Had a change of direction,
Head changes are VCT and billet custom cams
Precision 6766 cea billet wheel .84 twin scroll turbo
6 boost twin scroll manifold
Magnaflow fuel pump and fuel system
Motor is currently being assembled.
ERD in brisbane does a VCT setup for a 26 head with a custom billet cam to your liking and a vct cam gear,That i am having converted to adjustable :D
they say you can get 20 degrees out of it im unsure as of yet but im tuner and mechanic are very enthusiastic about the set up.Soon as its on the dyno ill post up some dyno sheets to see how it effects the larger turbo :D
I talked to a good mate noel who is good friends with the people at erd he said hes seen a old school to4z bush bearing turbo with vct and it bought it on 800-1000 rpm quicker spool time.
Will be intresting to see how it goes mate.
You can google ERD they are also a supporter of this website mate.
  • 4 years later...
I  know i have not been on for quiet some time due to real life a shithouse mechanic f**king me over and having to do a full rebuild after seizing my own property back from said unamed mechanic but things are comming to a head.
Where i am at
Motor is NUR engine i bought off another member on here a few years ago and since them i have had the entire motor pulled down and rebuilt,
Billet 276 degree custom cam shafts to suit a variable cam timing off a rb25
over size valves supertech double row springs very ported head.
86.5mm forged pistons rods all the goodness.
Currently awaiting a new 6boost manifold and 50mm progate split pulse
i have 2 turbos but i have chosen to go the smaller of the 2 a 6266 gen 2 precision over the 6766 dual bb precision.
I have a 26/30 6boost manifold and gate to suit the 6766 turbo ill be offloading once im finished all new never used.
Just a quick update i hope the car will be tunned and on the road early in the new year. pictures to come.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
