Hey guys,
what's the best air intake part to get?
I've been looking at Apexi Power intake...
What are your thoughts?
Oh and roughly how much more power does it give the car? And does it use less petrol?
Cheers :rofl:
Edited by macdog
https://www.sau.com.au/forums/topic/282595-air-intake-part/
Do you want to use the stock box with aftermarket panel filter, or pod filter?
With a panel filter, any aftermarket one will flow better than a factory one. K&N or Trust are ones I would use. You can get them off an R34 Skyline, or S15's. They are all the same.
Pod filter, well I like the Blitz Sonic Power intake kit as it has this cool alloy enclosure over the pod filter so should remain legal (I guess...)
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-4757900
Depends where you are located.
In Melb (OP locale), you can have a pod, but nothing else to the intake (piping, FMIC etc).
The pod MUST in a sealed airbox of it is instant defect... which IS enforced.
If you are wanting a pod, look at either;
3A Racing ~$30 (check out the Autosalon comparo for filtration/flow)
Blitz SUS Power ~$280 (Stainless Steel mesh pod which never needs replacing - can be cleaned - doesn't have the greatest filtration and is commonly found on extreme HP setups in Japan - 1000hp+)
Blitz Sonic Power ~$320 (this is a Blitz LM pod with the alloy enclosure to speed up the velocity of the air and make a certain noise)
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-4758744
  • 1 year later...
The pod may fit but the shield would not fit in as the 350z is quite different.
Looks pretty close actually.
That said, it would be an expensive gamble, but I am sure if needed the shield could be "persuaded" to fit.
Dalton, you got anywhere you can try one on to see if it will fit like a retailer/performance shop etc?
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-5455360
whats the performance difference be between the K&N flat panel compared to the pod filter.. i was lucky to get the flat panel one (oil based on with the pink oil) with my m35.
would there be much difference of power other than the throaty noise of the pod. and does anyone know if theyre legal in qld?
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-5456394
You guys have seen the M35 3.5L NA engine bays? They have the extra section removed from the air filter box. I wonder if we can buy that part???
The Powerduct? You can get it anywhere... try Nissan if you want to part with ~$180... or offer one of the V35 guys money for theirs :)
Or you could make your own with single sided adhesive rubber
yes, they plug straight into our airbox (I have one - freebee from a friend)
Edited by iamhe77
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-5456812
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
