Hey guys,
I got hold of a batch of Advan Racing Lug Nuts.
Got these at low prices due to rejects from printing issues on the nut body.
They are 60 degree acorn style, will fit most aftermarket wheels and some stock wheels.
12 x 1.25 will fit all Nissan, Suzuki and Subaru
12 x 1.5 will fit all Mitsubishi, Toyota, Honda, Lexus and more
Thread Pitch: 12 x 1.25 & 12 x 1.5
17mm HEX
Champagne color as shown in pic
Each pack comes as a set of 4.
Cost $33 per pack.
Also have some OE lug nuts as shown in pics
17mm HEX
Black color with 40mm length
Oxidize color with 50mm length
They are loosely packed and cost $3.50 per nut.
Will post at buyer's expense.
PM me if interested.
Cheers
https://www.sau.com.au/forums/topic/282696-advan-racing-lug-nuts-for-sale/
hey mate Advan released a set of locking nuts with a special key as well, can u get a hold of them? can im lil cardboard box i think with a set of keys
Sorry mate,
It does not come with the lock nuts.
Additional $10 to post.
Pickup is an option.
Give me a call on 0410588085
Cheers
sorry i should learn to read. do the OEM black ones come with lock nuts? how much posted to vic 3175? is pickup an option?
Hey guys,
Saw some guys asking about the materials of the Advan Lug Nuts and OE ones.
They are both made of steel.
If i have said the OE ones were aluminium, sorry about the mix up.
Let me know if anyone is interested.
Cheers
  • 1 month later...
Hey guys,
Got a bit of stock which i need to get rid of.
Dropping the price down to $25 per pack for the Advan Lug Nuts.
Postage at buyers' expense.
Let me know you anyone is interested.
Cheers
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
