whats similar is that they are auto stags with highflows....... its all the same basic principles / theories.
S1, S2, M35, all stags with the varied stagea features, auto boxes are auto boxes, and high flows are highflows. again a variety in types..... :)
May be the same principles, but... auto boxes are not all the same. The clutch packs in my box are just too small for the power I want to run. Unless you know of a manual that fits easy, I have no choice but to limit the torque output.
I installed the turbo today, also stuck heat shield around the turbo on the firewall as im not running the rear heat shield. Gearbox doesnt look like its going to be assembled untill next week, as the custom clutch parts havent been manufactured yet. ;)
  • Replies 68
look into the 34 getrag.. seriously. or a 33,32 gtr box in general..
from the brief moment i was under my car i'd say it would have to fit.
a custom bell housing maybe, drive shaft, and prop shaft and bobs your uncleeeeeee...
Must people seem to stick with the ball bearing cores when high-flowing, as some have the opinion that moving from ball bearing to bush bearing is a downgrade even if it is high-flowed.
I'd be interested to hear how you find the bush bearing though, just make sure you take good care of it and use a turbo timer or give it a few minutes to idle before turning the engine off etc.
Once I get the ecu remap out of the way and know they can tune the M35 I'll be sending a turbo off to GCG for a ball bearing high-flow. (can't wait!)
Not really necessary Stephen.
All you have to do is take it easy for the last block on the way to your destination.
Not only will it allow the turbo to cool down, but also the transmission, diff etc, which all need to cool as well.
You don't need to worry about the negatives that a TT brings.
Should be fine. If you see how the ball bearing units work you wont be as impressed, much the same as an old bike hub.
I would have gone with gcg if they had been more forward with information.
The car is back on the road after the tune. It managed 200 at the wheels at 14 psi, which is quite respectable I think.
The turbine housing still seems to be the limiting factor and is the hardest part to change so I think that will end the power gains for now. The injectors, pump and regulator would also need changing if any more fuel was required.
Im very happy with the Kewish Automotive rebuild on the gearbox. Shifting is quick and firm at all power levels without any clunking at all, highly recommended.
And I have some mates coming around tomorrow to help me fit the BC coilovers. Hopefully that will sort the handling out too.
Pretty sure Nissan have been using JATCO boxes in Skylines/Stageas since S3 R31's
Try the late 1960's - the 1969-built LHD 240Z had the 3N71A, the 3N71B/4N71B was used from 1970 through to 1988(ish) in a number of Japanese makes and then the RE401-series took over until the end of the RB. I'm sure the current model is a JATCO too!
PS good power Scott - considering flexible engine management is still a bit of a headache.
:rolleyes:
200 killa wasps at 14psi....good result considering I was at 17psi to get 199.99kw's!.......must be the intercooler and wheel size making the difference.
Are you using the standard boost controller or an aftermarket one?
Edited by Jetwreck
3" FMIC piping = less pressure with higher flow
Congrats on powahhh, bloody respectable I'd say. Interested to hear your thoughts on the BC coilovers too.
Cheers, Dale
BC is not buddy club
they are different brand
although i was told that it's the same factroy (not 100% on this)
Buddclub dont have anything for the nm35's yet
ahhh got ya, i assumed buddy club :D
yeah a few brands steer clear of NM35s for some reason......
ASS | U | ME
(mainly because I assumed they were BuddyClub as well) :yes:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
