And so the story goes like this.
This afternoon, I was at Kingsway, Glen Waverly, wanting to get some pork. While i was looking for a parking lot, my girlfriend suddenly felt pukish. So i just put on my hazard lights and ran into the shop to get a bag for her. When i came out, the girlfriend showed me the infringement notice.
It says STOPPED - DOUBLE PARK
And i have to pay $70.
Do i contest it? Or should i just pay the fine. The money doesn't matter so much, but i was gone for like, 20 seconds.
Yeah, you did something wrong so you technically would need to pay. But I personally would write a letter explaining the situation, and see if they show and leniency. Most likely you will need to pay.
Why did your girlfriend not talk to the parking officer? Was she even visible or was she like in the bushes chucking?
if you couldnt talk to the parking dude at the time, i wouldnt bother about it, fines been written and done, $70 is like a full tank, but not really worth the worry and bullshit you have to go through to cancel it.
or you could exaggerate the situation, saying you miss's was curled up on the front seat with bad pains, so you did what any boyfriend would do, and that asshole inspector didn't even care to see if she was alright while you were gone for all of 1min max.
give it a crack either way, the worst that can happen is that you pay your $70 :P
Common sense would have gone a long way here, if any one in my car says they feel like spewing they get kicked the f**k out, do you know how hard it is to get the smell of spew out of your car, not to mention how violated the car will feel, you have betrayed its trust, it will for ever hate you.
i always thought double parking was something similar to those tools you see just stopping in a lane, jumping out to buy ciggs and jumping back in. they are double tools when you want to reverse out and they're blocking ya. just pay the fine and be weary next time. did she ever throw up in the end? :P
Yeah she did, in that plastic bag i for her.
Well, all i did was stop behind 2 full lots, but i now know you can't do it here.
Alright, i'm too lazy to go contest it anyway, i heard its a super long process. Will just pay the fine i reckon.
You're lucky it wasn't the "Loading Zone" around the corner in Colemen Pde near the station. $117 fine for a 10 second stop - I always thought it was a "drop off" area since there's nowhere else to stop on that side of the road - unless you're a taxi. (I'm an unofficial taxi but that doesn't count.)
JH
And today when i tried to pay the fine, it says that the infringement number was not found.
How long do they take to update the system anyway? Its been 4 days, or 2 working days. Do they really need to take that long? I thought it was all seamless.
I think its pretty much instant, at the most it would be in there when they get back to the office.
Yeah I got some $70 odd fine for parking my car over night around the corner from the pub in a two hour zone. The only sign was about ten metres away with an arrow pointing along the wall. I did the right thing and didn't drive and I get fined for it :D Just payed up though. could not be bothered with the whole lengthy proses of contesting
If you follow the instructions at the back of the ticket, it should be right. Make sure you went to the correct site to pay for your fine. If not, just call them up and pay with your credit card through the phone.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
