  • 5 weeks later...
I own both, so screw j00 hippies :D
the TT supra obviously woops the crap outta the skylines, GTR's will get up and give them a go, but once you start to tweak them even a little bit the supra has the upper hand,
however having said that, the gts25t is a much lighter feeling car and seems somewhat easier to throw around than in the supra, or maybe its that i rather throw the r33 aorund heheheh
its a lot happier on fuel as well in comparison to the supra, but the power feeling under foot is completely different, doesnt help when comparing to a 3litre though as well.
so basically this post is pointless since you cant really compare chalk and cheese now can you.... im unable to compare to a stock gtr sorry :) which is all it can be compared too.
however upon selling the supra if i ever did, id have no problems going to a r33 gts full time at all ..
  • 7 months later...
word is u can push 600hps on a closed supra engine.
Close to 1300hp with happy gas is the record so far, for a "street driven" Supra, Doubt it would see the street, and no idea how many dyno runs it would last for, but meh top effort I say.
ska when someone goes check out my new turbo and they pop there bonnent and u see a t88 :( your mouth drops. goto supra forums and check out atomicfabio's supra :) full on nuts hehe. i love it :cheers: but still an r34 gtr or gtt with a do-luck body kit :D:D:D sex baby "oh yeh" as duffman says :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
