  • Replies 41
Posted Images
fark that car is outrageously quick if it only has 650hp...good work! its abolsutely killing those cars on the straights and still going thru the corners well.
well driven too
do you have more specs/info/pics of the car?
I think Power figures are Over quoted in Australia. The Dyno says more but the Turbo wont flow more than 650fwhp, Thats why I quoted the more real figure. The Engine ia an RB25, Stock head with Poncams, Greddy intake,6Boost manifold, Wolf V500 ECU, GT35 with small exhaust housing, CP pistons and Rev rods,All About 4 years old now, It started out in Hill climbs/Speedevents Also.Uses KW Coil overs and Arizona Zcar Willwood brakes, PPG gearbox
When we get the chassis right we will run an RB26/30 with a Spool 3.4 crank, Ive talked Steve into letting us sort handling before we fit it.
New Engine Package is around 900HP, As you can see Steve still has a bit to learn and we still have suspension issues so it can sit and wait.
My Son Jeff Built most of the car.
Some early Build pics here. http://s249.photobucket.com/albums/gg225/Stevethomas/
All co-incides when he clipped the ripple strip on the S bend. May have unsettled the car to lose traction, but looks like it may have caused the driver to give the accelerator an unintentional jab at that time.
Boost obviously comes on really hard, so balancing the grip and torque in the wet would no mean feat.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
