I'm really keen on a cost effective solution to this as I'm not far off final assembly!
Ive just got mine running with the N1 pump and paranoid now :D
Cheapest Reimax gear set i can find so far is 670 au + del. through Greenline.
Im using a Jun collar so a VLT pump is outa the question.
Did the N1 pump come in 2 different size gear sets 77mm and 81mm? http://www.greenline.jp/catalogue/bproduct...&fromlink=1
On the gears changing, I know there are some companies in China who are producing a lot of powdered metal parts, maybe Nissan started sourcing them from there? Whatever the case, I won't use them any more, or if someone wants to use one, it's their problem if it breaks.
I'm getting some info on the gear splining, should have some news in the next week or so about a billet spline drive gear set to fit the standard housing. I've also been cadding up a new front housing that uses an external pump, probably a single stage petersen one but doesn't get in the way of the accessory drives or anything else.
ive got a GTi-R pump at home and im going to compare the rotor set to the spare jun and greddy RB26 pumps i have here, they look very similar...... really want to get them side by side.
i'm not buying an n1 that's for sure. another fail thread came up yesterday. seems too risky. Don't like the idea of 2k+ for a pump though!!! someone must make some special collars and pump gears :D
My N1 pump blew as well. Sending all its internals through my engine and now it has to get a rebuild. However it was not the pumps fault, there was a leaking seal that made the pump overwork, thus destroying it. Well that's what the mech said. I am replacing it with a brand new N1 pump.
I think it was your post i was referring too. Wouldn't you be interested in not going back down that road? How big was the leak? making the pump work overtime you must have had a hole with your oil pouring out. just a thought.
A leaking seal? which seal? the less pressure you place on the pump the less likely it is to crack. Unless you ran out of oil I dont see how a leaking seal would break an oil pump...
Effectively a leak is like comparing a single turbo to a twin turbo setup, the only thing different that would happen at the pump is the pressure relief valve will stay a touch closer to closed at higher RPM and when cold, doesn’t effect the load on the pump.
Well just got off the phone with greg and we've decided that it'll be easier for me to make the gears and collars.
So, if your keen on a set send me a pm or register ur interest in here so i can gauge how many sets i need to get made in the first batch and i'll put up a group buy thread once i've spoken to my machinist to clarify prices and dates. Rough prices atm will be about $600 for the collar and gears.
The pump is for free. Warranty replacement. The leak was barely noticeable. I didn't even notice a change on the dipstick. The mech said it was a turbo seal that blew. I am not a mechanic myself so I wouldnt know if this would or wouldn't cause my pump to blow.
Makes two of us...
If it was my build I would be selling that N1 pump as soon as they gave it to me. After reading the stories on here there is no way in hell I would run one.
I hope I don't read a similar story in here again by you Jez13.
Quick edit,
You might be able to put some kind of meshing in the oil sump along with a magnet or two. If something shreds in the engine block then hopefully the magnet will pick it up before it goes through the engine and causes more damage.
Edited by [200]
I did a quick count last week and I am up to 32 N1 oil pumps used in RB's (20's, 25's, 26's and 30's) since 1999 and guess what? Not one single failure recorded by anyone, road or track. So I don't think I will be changing any of mine any time soon.
Cheers
Gary
Makes two of us...
Quick edit,
Hmm. Well here is a thought. We are only picking on N1 pumps. What about all the other pumps out there? Are they all blowing just as much as the N1's under the same conditions. If there was an external property that killed an N1 pump - then that pump got replaced by a more expensive brand but without the external property fixed, would that pump blow also? It's strange - 50% of people in this thread are for N1 pumps and swear by them and the other 50% of people wont go near them or have had bad dealings. Well for scientific purposes I will retain the N1 pump after my engine build. If it blows again then I will have to support the haters and make it 51% to 49% thus concluding that N1 pumps are a no go.
I know where you're coming from and I understand that there is more to it than just the pump such as build tolerances and rpm limits.
But having said that, if I was to spend 5k on getting a bottom end built I would be saving extra and buying an external pump or dry sump system. I know that a member of another forum had his N1 pump let go and he's now rebuilding with a dry sump.
Gary, r31nismoid whatever his name is mentioned that they might be using a different metal grade for the gears in the 'new' N1 pumps. I don't mean to be disrespectful towards you but when did you last build a motor with an n1 pump?
TiTAN, as mentioned, if it was ballance, mashing limiters and/or dampers causing pump fails the bearings would be mashed long before the pump as with all other pump sets that share the same design. Most N1 pump faliures when caught in time show no signs of bearing dammage at all... Some right away some only after 40k km's.
From adv search across 19 international forums over the last 2 weeks, each case is unique in description and username and date range.
23% - Standard RB pump on short pump drive
6% - Standard RB pump on full pump drive
68% - N1 pump (not specified which diameter) -
3% - Greddy, HKS and Jun
1% - Tomei – only 2 cases found
5% and less can easily be chalked up to build issues/ballance "external factors" in my opinion,
Use it, don’t use it… but it definatly isnt 50/50... Obviously sales volume also would dictate the above, that said I would guess there are just as many if not more stock pump w/ full pump drives running around as there are N1's.
Sydneykid, you are one of the only "builders" I know of that still using them. I am glad youve had success and value your input greatly... Unfortunatly there are many performance renound RB builders all having the same faluires all over the world for no apparent reason...
I should have the metrology results back shortly on the remains of the N1 I removed from my motor as well as a stock RB25 pump and a stock SR20 pump.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
