Yeh, you can break any oil pump. But in reported cases the frequency of N1 pumps breaking seems to be far higher then most other oil pumps...
At this point, reported cases are really the only thing we can go by when evaluating just how good or bad certain oil pumps are.
I went with a nitto pump on my engine, didn't want to take any chances with an N1
r33_racer how did you manage to post in the future?
That is because their market share exceed far and beyond probably all the brand name one's combined and then another zillion more units.
without documenting the history of each case - you cannot possible deduce or say N1 pumps breaking seems to be far higher.
That is factually incorrect I'm afraid.
So you do feel that there are more N1 pumps on the road than stock oil pumps? Because there are far more people posting N1 failures than stock, almost 10-1 ratio.
I would like to know if any of you guys have links to HKS, Jun or Greddy pumps that have just totally randomly failed without any other damage which could have contributed to the failure? I have found only one case of a totally random name brand pump failing that is not attributed to bearing/crank destruction due to possible out of balance or damper requirement etc.
Also if anyone has remains of any of the name brand pumps inner and outer gears I will happily pay air mail so I/we can have it tested at the same university as the N1, stock and SR20 is being tested at.
After all actual facts will speak volumes… but until I have hard material facts I am treating it as a rubbish pump till proven otherwise,
ash, i suggest you re-read post 177...
i did twice before i posted.
just making it clear for everyone else that reads this thread and might be confused by just looking @ the 'stats', which in all honesty don't show a thing.
Do you think there are more N1 pumps in use than stock pumps? because a simple search will show boat loads more N1's fail than stock... fantasic "upgrade" as you call it...
Basic stats are given, from a simple search, this simple searching showed loads of random failing N1's.. I am yet to see more than one random failing name brand pump...
I guess some like to voice problems it to work out why it failed... something along the lines of learning from mistakes/ not wanting to repeat them,,, I think the only mistake made in this situation was me being cheap ass and buying a N1 when I should have paid another $400-500 and got a decent pump.
How many stock pump equipped motors are being pushed?
How many are still factory?
How many motors die and get rebuild with a factory pump to factory spec? How many to a high spec/power/stress?
How many motors die and get rebuild with a N1 pump? How many of those were done by less than experienced builders following the workshop manual?
I could go on, however i am sure you see my point i am trying to make here.
Your numbers of failed pumps is good, but that is all it is, a number. A stand alone number that for the most part takes nothing else into account.
I see statistics/numbers daily @ my work that managers fear them at times, but investigate further and often its a different story.
I still want to know what the hardness of the material is in a stock vs N1 pump.
I'm currently using a stock R33GTR pump on a R33 GTR crank/R33 based bottom end, and it's been the same pump for the 5 years I've had the car.
Good so far,....touch wood!
Hardness doesn't really mean much in terms of breakage, if it was pumps wearing that would be an issue. You could make the gears out of carbide and it's super hard but would shatter if you used them. 4140 is not as hard but will flex without breaking which is what you need for a gerotor gear.
Greg and Michael are on the money...4140 would be ideal. Beautiful thing is its readily available and not that expensive, especially in round bar.
Lol, about carbide, it is uber hard and doesnt like flex or impact. I broke a $200 solid carbide drill not too long ago, whilst drilling ally of all things! I now know not to peck, and to let it dwell first before actually cutting.
I tried posting this this morning...but it wouldnt work.
Ash, you might look at the stats on it all and see that technically it might not be true or accurate based on the accumlated info that rezlo has gotten in comparison to the rest of the stats out there which nobody knows other then nissan and how many N1s have been manufactured and sold....but anyone with an ounce of intelligence isnt going to take a chance when building a new motor, especially if its a big dollar build. And most who wouldnt know, would buy an N1 pump as its supposed to be an upgrade from std for a decent price too. But people do have problems with them, especially when they are leaned on in high reving, decent horsepower motors, but as you have pointed out many times other dont.....But even if the percentage overall was only 1% of reported cases, that would be enough for a clever enough man to weigh up whether he wants to risk it or not. Id hope he wouldnt, because who wants to take a chance when outlaying money?
If an N1 pump cant handle abuse on a performance motor in a sports car, whats the point in using it, really? If you cant limit bash if you go drifting (or burn out comps), or sustain high rpm for extended sessions in circuit racing, or place it under extreme loads at the drags with high rpm dumps/antilag/launch control, why risk using it? These seem to be the things which people often ask when finding out about an N1 failure, probably because anyone who has a skyline frequently does these things. If in more then a couple of reported cases an N1 pump cant live in these conditions then its a piece of CRAP imo and should be only used in std road cars as a replacement for worn out std oil pumps and nothing more.
You say its only a number/s, I say its a good enough collection of numbers saying dont risk it.
Kudos to rezlo for trolling forums to collect it all too!
On another note, I dont know how I posted in the future....but i like it!
Of course an N1 pump can't handle that...
Once again however comments are made as if every other pump can handle it - which they simply cannot. ALL Pumps WILL FAIL if you abuse them.
That is all the numbers really say to be honest. An oil pump, can be killed, wow... Hardly new information to the world now is it?
I'm not saying the other pumps are not better for the $$ spend, of course they are. Tomei is the pick of the lot/most chance it will take the beating.
A bigger $$ one might last longer, will it last forever? Simple answer is highly unlikely.
So by your own reasoning every oil pump is therefore a risk is it not? (now, how silly does that sound?)
Furthermore everyone should dry sump without question regardless of their needs or requirement as risk is not good.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
