Chinese cast iron blocks are not a nice thing from those I've seen, the same with cylinder heads. There are copies of the Dart Chev blocks coming from China now and they look good but the hardness just isn't there and the geometry apparently isn't great. There's a long thread about them on speedtalk at the moment.
Some stuff from China is really good, including many of the cheaper US branded conrods but a block is a lot more complex item. There are even fake ARP bolts being made there, it's good to know that the Spool rods run genuine ARP bolts, they arrive in the ARP packet separate to the rods. Some other rods around have bolts that look a little suss, they have ARP stamped on the head but not the finish you would expect on the rest of the bolt or no brand at all.
haha yeah i just rejected a whole lot of PROCOMP gear (heads, sheet manifold etc) as it was all junk. It is just a joke, but other gear from the right place (non procomp) is actually quite good ie stroker cranks and so forth all seem to be spot on
I read somewhere that Dart were boycotting (or getting people to boycott) the Chinese copy blocks and buy original Dart stuff.
Dart are smart, they have dropped the cost of their blocks to gain back the market, great idea if you can afford to do it. The rest of their products probably cover the cost.
The thing with Chinese stuff is, if you specify exactly what you want and supply drawings etc, then get samples, then keep a check on the quality, you get a good product at a good price. I've used some chinese 4g63 and Subaru cranks and they are not bad stuff. Spool rods, wherever Brad has them made are made to his specs and are better than the competition. He does supply specs, drawings and such for what he gets made. I know this for sure because I did a little cad stuff a while back for him.
The problem with some parts is they make them to a price rather than a quality, it used to be the same with Taiwanese machinery, it was junk, now it's some of the best around. Chinese stuff will get better as time goes on. Look at their space program, at least one out of every 3 rockets they launch now actually makes it into space and doesn't crash into a town near the launch site. One day it will probably be 2 out of 3..
i did this for my i/c silicone hose kit, worked out well in the end
haha greg what a statement lol...thunderbirds are go!
Are any of these engines with failed pumps using bypass filtration? I understand the design spec issue and tolerance theories, but the comment about gerotor sensitivity to junk makes me wonder if it might be partially mitigated by better filtration?
Edited by WizardBlack
Does anyone have an idea why the nitto pump has been changed to use a billet cover plate rather than the cast one they originally had? Call me paranoid but I just fitted one that had a cast cover plate.
the cast plate ones are fine...relax greg...ive used quite a few of them. Ill find out the reason for the change of you like. The answer...evolution...Nitto are constantly reviewing their product range to stay well ahead of the competitors offerings. Anything that can be seen to be improved will be upgraded/updated.
Edited by DiRTgarage
I'd be very interested to know Paul, thanks. The new flyer is a little better written anyway, it would be nice to know the grade of metal used for the gears, just saying "EN series" allows a pretty big variety of materials.
The pumps look the part, I still think the relief pressure they are set at is way too high though.
they are the same as a stock SR20 pump...no drama's with them...even at tight factory bearing clearances. Im happy with them after speaking at length to Nitto about it.
"NITTO has now released a new billet alloy backing plate allowing further stability to oil pressure and flow at high rpm levels by minimizing any possible flexing of the housing"
Does this mean that they were finding their original ones with the cast backing plate were flexing?
Also i remember reading from one of their previous pump descriptions that they were using EN46 for the gears...
"possible" is the operative word here. Im sure they didn't have an issue...but more the fact they wanted to prevent anything being the weak link in the chain.
yep Shane EN46.
Given that you've spoken to Nitto, do you know where the pumps are made? I'd have more luck finding Mr Snuffleupagus than info on Nitto.
I can assure you yes...they are made here on earth.
What is your concern with the pumps high crack-off pressure?
Nitto gear is not made in Germany thats for sure.
Got some info ?
Greg im sure you already know Mr Snuffleupagus is found hanging out with Big Bird on Sesame St.
Dave you typed a lot...for no response...if you have some info and you have decided not to post it feel free to PM me.
Here's Nitto's distributor website...its black and white.
http://www.tweakit.net/shop/product_info.p...roducts_id=7204
to be honest i couldn't give a rats arse if i found out they were produced by blind buddist monks in the mountains of Tibet...they are an excellent product that ill continue to use on all our engines.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
