  • Replies 716
Posted Images
Yea yea typical male line fat boy,,,"oh the women forgot to do the wheel nuts up". Fess up hommo,,,we all know Jenna was doing the electrics and you were sitting on ya fat arse drinking beer wondering how to put a wheel on one handed.
I hear it eveyday pal,,bloody wife smashed the mirror off again,,,bloody wife smashed the car again,,,bloody wife reversed into what ever. Blah Blah bloody Blah.
Cheers
Neil.
  • 5 weeks later...
Well after cracking the shits over the no oil pressure motor and parking the shit heap in a corner for 2 months it's time to get it going again before cams change the rules on me.
In other news we took Jennas car to marulan, texi skids and Wakefield on the weekend which has now re motivated me. Managed to snap her gtr seat in half, which was a suprise mid corner.
Picked up the remaining gear to log book the car so time to get it on
Yea baby
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
