  • Replies 716
Posted Images
Believe it or not pete's car is not that bad.
It's sorta done okay, kinda, in some ways....
His got it back was going to the dyno straight from here so I'm sure he'll post up how it went, if it went.
yup just got back
tops work brad!
champion
252rwkw at 13psi
so should do alright
did run 260+rwkw but was pinging and shit
pants of to brad for the tops work and hitman for the tune
excellent result pete...once the boost restrictor is on you will need to drop to 12psi but you should still be 240kw+
why pinging on higher boost? was fuel pressure OK? or just injectors running out?
It's probably still got the same fuel in the tank from when he bought it!!!
Wouldn't surprise me one bit ;)
We pretty much preped the whole car front to back in a day and replaced the blown manifold gasket.
All fluids, alignment, brakes, attessa repairs blah blah.
yeah that curve looks excellent considering that everything is standard.
and good work brad tidying it up the car so quickly.
good luck for the weekend....2 hours racing is a hell of a shakedown for a brand new car. Mine gets through a tank of fuel in about 55min so keep an eye on fuel surge from about 50min
You forgot to mention that he needs to remember to put fuel in the car to begin with... ... ...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
