I'm confident it would be @28".
You see above #1 it says CCFM, that is calculated cfm which with Audie software is either at 10" or 28" water and if the head is flowing those numbers at 10", multiply them by 1.67 to get flow @ 28" and you have a head that flows 511cfm @ 28" intake @ .5" and 392cfm on the exhaust at the same lift.
That's in the range that a 500cu/in pro stock head flows @ .8" lift and makes around 1300hp naturally aspirated @ over 9500rpm. On an RB26 it would have a sweet spot around 20,000ish rpm..
They are very good exhaust numbers, what sized valves is the head the data is from using?
+1mm oversize on intake and exhaust.
I am curious to see if anyone would like to compare any other flow figures they might have for an rb26 with the price they paid.
Core head assembly is $850 USD
CNC porting is $1760 USD
It is from theoldone.com
  • Replies 40
That's not a bad price for what you get, including a brand new head. You'd need to run their roller wave pistons as well looking at the lowered intake quench pad. Endyne came up with their "soft head" design and looking at their Honda engines, it works.
I just want their workshop, it's very impressive.
Soft head? For those who don't know and are willing to learn it means...
Mike, have a read at http://www.theoldone.com/components/pistons/index.html there is a basic description of the roller wave design near the bottom of the page. If you can access the old forum on the website there is a lot more about it there.
These guys are running very high comp 11/12:1 with forced induction and the right cams and making some unreal power from Hondas using this design.
pricing seems pretty fair. and the work looks very nice. I wouldn't hesitate to try one. you would be wise to use a set of their roller wave pistons as awell to get the most out of their chamber design. head looks fairly similar to the guy I use in japan as far as what he does with the quench pads and for the same reasons too. using their special pistons I imagine means you can reap the benefits of the revised/removed squish zones without the disadvantage of loss of response (piston design gets it back).
http://www.bulletcylinderheads.com.au/nissan_rb26.php
good flow figures as well and local (SA), i still haven't sent my SR20 and RB heads of to them yet but ive seen good results... from a customers engine.
Edited by URAS
The bullet figures look great too. very close. giving away a little bit of flow at higher lift but are on top at lower lift which is good. and overall not as much exhaust side gains. but they don't specify what valve size just that you can ask for std or oversize.
What do you guys think about making your intake port smaller??
And this figure came from an stock yamaha R6 only with the intake part has done the "smaller" porting size.
I know its for a motorcycle and a Natural Aspirated engine, could we have similar result if its been done to our the RB's?
Yamaha R6
- Stock Ports 103.1 HP
- 20% Smaller Ports 104.1 HP
- 30% Smaller Ports 108.3 HP !!
CBR 600F3
Before & After
The Blue Line represents a cylinder head that was "flow bench ported" by a well known U.S. motorcycle performance tuning company.
The Blue Line shows that enlarging the stock intake ports a small amount, caused this engine to lose power throughout the entire power curve.
The good news is, The Red Line shows that after fixing the "flowbench ported" head by making the ports 35% smaller... this CBR 600F3 gained more than 10 HP !!
Since The Blue Line's head ports were already "flowed out" even bigger than stock, there was about an extra 3 horsepower recovered.
In this case, a stock head would have worked better than the flowbench ported head.
Feel free 2 comment....and for the full URL:MotoTune USA
Yamaha R6
CBR 600F3
Before & After
id say that bike was probably under cammed for the " fully " ported head work. Its the same principal with most engines and here in aus the 4V cleveland is the most well known. We fit tongues into these engines (4v heads) all the time to increase airspeed when running mild to hot cams and 4v heads, but whack in a BIG cam and the ports come into thier own..
Just to add to this, i've only ever seen cnc heads guys advertise Rb26 heads, but even though its not on there website (that i could see) , Bullet say in there magazine adds they have programes for the rb25 and rb20 also.
Seems like a few engines have there intakes ports made smaller.....another is the old school 2 litre pinto found in Cortina's and Escorts. Fill intake port floor with Devcon on race motors with big cams and torque and hp climbs.
I also made twice the stock rwhp with mine using stock carby and cam with same duration as stock (268 degrees) but more lift and head porting by me with larger rimflow valves - good enough to pull faster lap times than my neighbours XAGT coupe around Barbagello and within a second of my brothers C.O.M.E built 355 stroker Torrie.
Edited by juggernaut1
Dude, I gave you a link to Lewis Engines on the last page where it has their RB20 and Rb25 and Neo heads.
these are of a 26 head i had done for a monster rb26/30 33gtr i'm building for a friend. all the headwork was done by will @ jhh in brisbane. basics are 1mm os valves both sides & what he classify's as a 'race master spec port, polish & chamber work'. all port/chamber/valve seat work came to $1500.
I must say though, you shouldnt base the real world performance of a head on what it flows on a static bench, you should only use a flow bench as an indicator only.
^^ those figures dont seem too impressive....but flow bench figures aren't the bee all as you say.
In fact my mate with the 6 second capri who does all the cylinder head work does not even use his flow bench anymore..he has chased figures on the flow bench only to see nothing gained or even less on the engine dyno.
So these days i just trust his knowledge when he says its going to make good power it will..dont worry about flow figures
engine hasnt been run yet so i cant say how it performs.
pics of the head are in here - http://www.skylinesaustralia.com/forums/Rb...es-t245266.html
yeah like shane said the numbers don't tell everything. there is a whole lot of complicated shit going on inside a 4 valve combustion chamber that cannot be completely explained just by the figures the head flows. it gets even more complicated when you add boost as we do... the proof of the pudding is in the eating... shane will know if the head is any good when the thing is running.. :P
    • Great interview on damper settings and coil selection by HPA https://www.facebook.com/HPAcademy/videos/30284693841175196/?fs=e&s=TIeQ9V&fs=e
    • Yeah, it was a pretty deep dig.
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
