Hey,
As some of you may know i have pretty bad strut tower rust, now that my tax back money came in, it is now going in to ger fixed up, along with the hold under the battery for a intercooler, which is no longer there.
i've chucked it in with PJ Panels, here in Victoria Keysborough. who has 35yrs under his belt in the business, and nothing but good work i hear coming out of his shop.
anywho, thought i'd just start this thread now as just got back from leaving the car with him and i have some Before photo's.
the photo's you will see are just of the struts, and a little patch near the ABS system, where some sort of glue was put on for some reason.
the strut with the big line of rust is the passenger side, and the other with to big holes is the drivers side. and everyone know's what a intercooler hole looks like, not pretty.
i might even be able to get some 'in the process' photo's during the week.
https://www.sau.com.au/forums/topic/284534-strut-tower-rust/
yeah mine started of really small, and it just went a bit stupid.
$180 ? is he just going to bog it ? or actually replace with metal ?
cause when i took mine done there he started picking at it, and notice someone has tried to fix it in the past with bog, either over in Japan, or 1st owner here.
Micah, any sign of it coming back ? what they do to fix yours ? was it just the plate or the actual tower underneath ?
We had a fair old dig at it and it seems to be just the top skin/layer lifting up off the actual tower. No bog being used, he seems to think only a small job
ah yeah sweet, has a feeling they weren't sealed properly. hope your right *fingers crossed*
same here only the top skin: had the rust filed out, then treated for a couple of weeks. Following this, had a couple of new spot welds (I think), then a splash of paint... It was done a few months ago now, but no sign of any issues again: I do keep an eye on it now, though...
  • 3 weeks later...
bit of an update, it took longer then expected.
went and saw the car today, all finished and looks bloody nice! almost like its never been touched. when i grab it tomorrow i'll take a few pic's, and hopefully he still has the photo's off the repair in stages.
stay tuned!
these pics are from when everything was cut away and the new plates put in. (wont be receiving the other pics till the weekend)
you will notice and bit of surface rust on the car in various places. thats for another mission if i get obsessive with it :P
this is where the rust problem starts. its not completely sealed off and water gets in
Intercooler Hole
after i got it back today. 4 quik pics. i'll clean the bay and get rid of the engine cover that was cut for my intercooler pipe. ( if anyone wants to swap for there uncut one to fit there cooler PM me )
i would say, it looks brand new ? very bloody happy with his work !
i huge weight has been lifted off my shoulders knowing my cooler hole is patched up and strut tower rust is fixed :P
TJ
If you are have had that much rust up the front end have you had a good look at your rear end.
I was under mine last night, removing the exhaust. The rear cradle and the underside of the wheel well are fairly rusty and need work.
I started searching last night for a rear cradle replacement and found a pic of someones craddle had actually broke where one of the suspension arms fix. Scary, esp if this happens of the highway or on a tight mountain road.
yeah i check it out real good when it was one the hoist.
didn't look at the cradle that good. but my panel beater told me when i got spare time and some spare cash, it would pay to get the whole underside of the car sprayed with Fish oil. stop rust getting any worse then what it is.
but yeah didnt notice any rust under the car, just your normal brown tinge metal, not orange rust shit!.
next mission. door mirrors !
Very nice job TJ,the stag came up very nice very clean and professional job ...no wonder why you want a cleaner engine bay :) (btw thank for the chance to get more pics of the guts of the stag...did you remove your hpi fmic?)
Very nice job TJ,the stag came up very nice very clean and professional job ...no wonder why you want a cleaner engine bay :O (btw thank for the chance to get more pics of the guts of the stag...did you remove your hpi fmic?)
haha no probs freddy.
yeah swaped the HPI FMIC for a Trust return-flow FMIC. its painted radiator black already, and the rows run up and down like a radiator. so a bit more stealthy. just waiting for funds to get the new front bar then this shit can start to happen :rofl2:
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
