Hi all,
Ive got a series 2 r33 gtst running with an rb20 remapped ecu. My AAC has been disconnected (was like that when i got it) ive been told this doesnt work with the remapped ecu and is the cause of my idle hunting issues...so was wondering if was one can offer any advice or at least confirm that this is true.
Cheers,
Lucas.
Edited by stolen-gtr
https://www.sau.com.au/forums/topic/284594-r33-gtst-series-2-rb20-remapped-ecu/
Thanks for the responses guys :(
So am i right in saying, basically the short answer is the R32 ecu that i have will give me fail idle unless i get a new Z32 ecu remapped to work with R33? How much is something like that going to cost me?
cheers,
Lucas.
The AAC does work with Remap but as you have R32 ECU you have no VVT , Ive seen some Dodgy Perth tuners ground the VVT so its on full time causing shit Idle and lack top end power. R33s need to use Z32 ECUs with remap.
DOn't waste your time with a Z32 ECU, or even RB20DET ecus
http://www.skylinesaustralia.com/forums/Po...ad-t210097.html
You can buy nistune off their website, nisstune.com it's $440 for R33 ECUs, solder yourself or pay a sparky to do it
thats not nistune, its a remap.
from the nistune website-
Note ECR33 RB25DET Skyline can use Z32 VG30DETT ECU with minor wire swapover
We are thinknig about doing a board for R33 RB25DE/RB25DET but it involves a fair amount of work, and the parts to interface with the existing 84 pin MCU on this ECU. It is a very difficult board to get started on and requires whole new firmware code to be implemented, whilst supporting customers with our existing product line. I will start drafting schematics once Type 5 has been finished and we have got the knock sensing functionality working.
If you are looking for something to get these going then we suggest either using a HCR32 Skyline or Z32 300ZX ECU with a Type 2 board. See our FAQ topics for more information regarding these ECUs.
Your other option, if you really want to use the R33 ECU is to use an emulator with an expensive third party daughter board (pictured above) available from Sam at
www.drdrift.com.au
Cheers guys, i really appreciate the help. Ill be sure to look into this further when i can afford to upgrade my current setup :thumbsup: but for now i guess ill just have to live with the occasional idle hunting.
Thanks again to all who gave their input.
Lucas.
with remap you have to tune every time you do new moods but nisstune can be updated all time
like others said z32 ecu for r33
If you change mods(eg;change to big turbo) you need tune again.
Its same remap and nistune.
nistune updata means change map.
If you go to tune shop for change map you have pay to each time.
nistune saling software and board.
Board is no need emulator but its same remap nissan ecu.
Im using R33 doughter board(not nistune made) and nistune softwear.
nistune is not same power fc , motec , FCONV.
Its same nissan ecu remap.
Thanks for the responses guys ;)
cheers,
Lucas.
No what people are saying is that you can get a good idle with the nistune chipped ECU, you have unplugged the AAC thinking that the chiped ECU can't control i with this isn;t the case, the chipped ECU can control the AAC so plug it in and get a tuner that can do their job.
People were saying that you will lose the VTC with the rb20 32 ECU which is the case, but with the VG30 ecu you will retain the VTC. From what i have heard about the VG30 ecu's is that there are a few pins that have to be swapped though to make it work with the RB25 Loom.
your confused, you need another board that NISTUNE DONT sell, but you can use thier software to to tune it. Sam @ DRDRIFT brings in his own boards and then uses nistune to map it.
Edited by URAS
Do you offer a similar service for rb25det or z32 ecu Trent?
Looking to trailer my car to you when the motor build is finished
Im happy to do the Z32 ecu swap but personally i dont use the high cost r33 boards ( i just use PFC, LINK or HALTECH etc)
Sam @ DRDRiFT is the only reputable shop using the R33 boards, im sure he keeps good stock if you need to go that route.
Are these any z32 ecus? does it matter if its from an auto/manual/turbo/non-turbo? from any particular year?
thanks
thanks
the later the better, as they are a better ecu. turbo or NA no big deal.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
