Het gotRICE, what you talking about
I know I have these specs with my a series 1 r33 gts25t..... I actually tested 1st to 4th speeds out today
Drivetrain
Transmission 5 speed manual
Gear Ratios Maximum Speed in Gears (* theoretical)
1 3.214 62 km/h (38 mph)
2 1.925 104 km/h (65 mph)
3 1.302 154 km/h (96 mph)
4 1.000 200 km/h (124 mph)
5 0.752 266 km/h (165 mph)*
As far as I know mine is all standard Diff/Gearbox.
Weird, I wouldn't have said it made those sorts of speeds either, but I plugged the gearbox ratio / diff ratio information in, and it seems to come up similar. From a quick poke around on the site, R34/R33 manual gearbox have the same diff ratio of: 4.11 (apparently auto r34 is more like 4.0, and 4.363 on r33). And using the gearbox ratios as above (which seem to match up with what I've read through google/sau-search, of 1 - 3.214, 2 - 1.925, 3 - 1.302, 4 - 1.000, 5 - 0.752). And taking into account R34 wheel size of 225/45/R17, and 7500RPM...
R33/R34 Manual
1st 67kph
2nd 113kph
3rd 167kph
4th 218kph
5th 290kph
I would have said the figures were slightly lower than that from my own personal experience, but it can't imagine it would be too far off.
Reference URLs:
http://www.darktide.net/~jrm/topspeed.html
http://justskylines.com/skyline/knowledgeb...calculator.aspx
Well at the drag strip i was reading 13.7 @ 100mph, and 100mph is 160.9km/h, and i was well into 4th crossing the line.
Probly not the greatest idea to admit doing 200km/h on a public road either.
But i guess where our debate conflicts is at what RPM are you reaching 160km/h? Clearly if your shifting at the stock redline then id say i was correct. But if your talking about non-standard rev limits thats a different story.
Both of thosae videos are pretty spot on at shifting at 7000rpm. If you went to 8000 then sure you'd get 160+ easily.
Edited by gotRICE?
Not the greatest idea to assume it wasn't done on a dyno / drag strip / race track / private runway either
you should of been well into 4th.
When you change from say 3rd to 4th at 7000rpm the revs dont drop to 1000rpm do they?
It will drop from say 7000rpm to like 5000+rpm depending on the driver. So you would be doing 5000+rpm in 4th @ 160km/h "well into 4th i'd say"
I fail to see your point in that post. As your now not disagreeing with me, just trying to pick a hole in a comment made.
Regardless of how we interpret "well into 4th", me meaning i was in 4th for a second or two before crossing the line. Not just releasing the clutch as i crossed it. I was hard back on the accelerator.
Go out to your private airstrip/dyno/drag strip, hold the revs at 7000rpm in 3rd gear, and take a picture of the speedo. The 2nd video CLEARLY shows that @ 7000rpm the car is only doing approx 145-150km/h.
lol,
its like 5-10km/h off, take into account that video wasn't made when the car was brand new and that the gear speeds are theoretical as I stated.
You don't even know if that video IS a completely stock car down to exhaust and rims.
Anyway your the one who said....
Dont know what R33 box/diff your running but it doesnt make 160km/h in 3rd.
in return to someone saying....
Just put're in 3rd gear, RB25DET GB+Diff goes up to 160km/h or so in third and you should feel a bit of pull
When clearly 3rd gear can do a "theoretical" 154 km/h (96 mph)
im not being picky I just think you where wrong to say "it doesn't make 160km/h in 3rd." :D
yer just anotherthing if i dont have any cold air intakes or pod is having a fmic still considered unroadworthy in victoria ?
In VIC you can only have one intake mod.
So either a FMIC or an air pod.
Some ppl go both but they shield up the pod, its a bit dodgy, but you can do it that way. LOL!
D'oh, okay I got my cars mixed up - I was thinking my N14SSS for 7500rpm, not R34 - which is 7000rpm redline :D
.. guessing r33 is the same?
1st 63kph
2nd 105kph
3rd 156kph
4th 203kph
5th 270kph
By my calculations using RB25DET Gbox/diff(4.111) in 3rd(1.302) with with 245/45/18's = 26.68" dia, = 167km/h @ 7,000rpm, which I did only 2 days ago
But that wasn't my point, the point is if you want to feel the boost, 3rd gear goes high *enough* that you can safely go down into it when on the highway
Ahhh that'd do it .. 245/45/18 is *huge*. I'd highly doubt that's a legal fitment, speedo would be nearly 7% out... AFAIK you're only allowed a 10mm diameter increase without it getting engineered (and requirement to get speedo recalibrated).
225/45/17 = 634.3mm diameter (1992.7mm circ)
vs
245/45/18 = 677.7mm diameter (2129.1mm circ)
... Which would explain why the speedo is reading 167kph :D ... You're actually only doing 156kph (107% of 156kph = 167kph)
vs
... Which would explain why the speedo is reading 167kph :) ... You're actually only doing 156kph (107% of 156kph = 167kph)
If you had larger diameter tyres, it'd be the other way around. Your actual road speed will be higher than the displayed speed on the speedo.
D'oh! You're right!
I got it the wrong way around .. *confused* ..
.. so the speedo would *show* 156kph, but you're doing 167kph with that sorta circumference change - Well there goes that theory on what's going on!
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
