  • Replies 64
this just appeared above the web page :cool:
Warning: Unknown(../vbp_includes.php): failed to open stream: No such file or directory in /home/skycom/public_html/global.php(929) : eval()'d code on line 2
Warning: (null)(): Failed opening '../vbp_includes.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/skycom/public_html/global.php(929) : eval()'d code on line 2
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-591415
avatar changing is rooted... only allows you to delete, propbably coz the avatar library is in a different dir now.
Half the emoticons don't work, again I think its the same problem.
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-592849
I've finally managed to post under another username.
My original username is 'Shane'. I've had to use this username to post this bug.
When the forums came back up, I updated my email address for 'Shane', the forums should have sent out a confirmation email but I didnt get one.
I assume there was no emails sent out at all by the server in past 4 days or so e.g. subscribed threads, newly registered users...
So basically I'm locked out of my 'Shane' account.
The pasword reset is now sending an email but its not doing anything, and says invalid password.
Can my account be reset or something?...
Shane
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-592872
I just thought I would reiterate (spelling) what funkymonkey said in regard to avatars...
I can't upload or even do anything besides delete my current one which I did by mistake thinking it would take me to an upload/update page for my avatar...
I know the new vBulletin will take sometime to get running perfectly, but as the thread says..."Bug Report"...I haven't noticed anything else, but I never really used it to it's fullest abilities anyway...:-)
Cheers.
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-593657
Quick insignificant one...
In the user profile screen the following is stated:
If you select your birthday then other forum members will be able to see your birthday on the forum calendar and in your profile. Adding your year of birth is also optional.
If I try to add my year of birth without a month / day, it doesn't seem to stick.
Month / day without year works fine.
Month / day with year works fine.
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-593688
Hey Guys,
The uploading images thing will be fixed shortly.. simple permissions issue.
Strutto - Its because I have setup the 'age' thing on the left.. if you post the year, it wants to calculate the age, so it needs the others... if you dont post the year, it will ignore the 'age' field entirely.
Christian
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-593716
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
