Hi Prank
Know you are really busy with all this stuff at the the mo but HELP--
My usual login is blackdoggette - I can login ok and forum recognises I am online but as soon as I try to post, look at my profile or PM someone I can an error back (largish) that looks like I am not activated or something???
I joined about a month ago so am assuming with the recent forum death and re-birth that something is very amiss...
I sent you an email (of course I tried to PM and post but couldn't) very early today and hadn't heard anything so I joined forum again tonight using this username - Nissy
Help
---many many thanks
when it gets all sorted I will let you know and you can delete this account
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-595091
  • Replies 64
Hey just a fiew things, you probably know them all already.
1. in the change avatar option there is only the option to delete.
2. Webmail isn't working? Outlook works fine tho :rofl:
3. FTP to upload to webspace doesn't work? (ERROR: Windows can not access the folder, make sure you typed the file name correctly and have permission to access the folder.) in the pm you sent me you said
*Server; ftp.skylinesaustralia.com
*Location; http://www.skylinesaustralia.com/members/endorean/
thats not my username perhaps its pointing to someone elses webspace?
That is All :D
Thankyou Very Very much :)
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-598140
PranK,
It appears that you can edit other people's gallery images, manipulate them and add text. Obviously there is a very bored/sad soul out there which finds it funny. Don't know what the login area for it is for? Username and P/W don't work there??
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-600010
You would have to be pretty bored. Would be good if the only people who could edit your photos, are you and the moderators. Still wouldn't stop bored souls posting rubbish though and as the gallery grows, it may become a problem keeping track of it all. It will be a damn shame if stronger restrictions then that have to be put in place.
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-600414
FTP should now be working.
Sing out if theres problems.
C:>ftp skylinesaustralia.com
Connected to skylinesaustralia.com.
220 SAU FTP
User (skylinesaustralia.com:(none)): [email protected]
331 Password required for [email protected].
Password:
230 User [email protected] logged in.
ftp> put boot.ini
200 PORT command successful
150 Opening ASCII mode data connection for boot.ini
226 Transfer complete.
ftp: 192 bytes sent in 0.00Seconds 192000.00Kbytes/sec.
ftp> ls
150 Opening ASCII mode data connection for file list
boot.ini
ftp: 10 bytes received in 0.00Seconds 10000.00Kbytes/sec.
ftp>
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-602587
dude all links that don't point to forums.skylinesaustralia.com/forums don't work. I think it used to be either forums.skylinesaustralia.com OR www.skylinesaustralia.com/forums.
Even the notification emails are wrong :D
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-606797
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
    • Good on you for mentioning, that helps as far as other things you might need to check
