ey fellas
need some advice, i wanna build a hybrid motor with an RB30 bottom end with either a RB25 or RB26 head. the dilema im having is trying to find out which head will bolt straight on with the least amount of modifications? ive read some of the threads on RB30 conversions but still cant find one that will answer my question
cheers
https://www.sau.com.au/forums/topic/285088-need-some-help/
Theres an rb30 sub-forum in the force induction forum
rb26 is a direct bolt on but the block will need to be tapped out to take the 12mm headstuds
rb25 needs an oilfeed for the vct uses 11mm studs and are a direct fit to the block rb30 is 11mm (head needs a lil modding)
plus side is rb26 has a much better looking plenum however if its going into a gtst it will cost alot for custom piping (easily 2-3k) if u opt for a forward facing plenum
i think cubes has a rb25/30 with a low mount on the stock manifold with 400hp
the rb26 can mount a pair of -10s onto the stock manifolds (see Marko R1s thread)
https://www.sau.com.au/forums/topic/285088-need-some-help/#findComment-4788626
The head Ryan is talking about (R32 RB25DE) is the EASIEST head to use if replacing an RB20 as everything plugs back in and will run on the stock ecu (which you can then have remapped).
If you have any specific questions, feel free to shoot me a PM :P
https://www.sau.com.au/forums/topic/285088-need-some-help/#findComment-4789095
Hey guys
Ive tried surfing the net but i cant find the appropriate information. I'm just wondering if any knows or has a link to a website or a picture that shows the timing belt assembly of an RB25/30DET motor?
Also ive been hearing that i may have to put a new tensioner onto the block for the timing belt to be able to go on?
Whats the best way to get a good compression ratio with good response out of this motor?
Is it better to use a RB25DE or RB25DET head for this kind of conversion for results in compression and response?
thanks
Edited by Morgz32
https://www.sau.com.au/forums/topic/285088-need-some-help/#findComment-4790765
hi gtst v-spec i tried opening that file for the build but its a winzip format and i cannot open it or save it and then open it.. any other ideas or does someone have it that and would kindly send it to me??
thanks
https://www.sau.com.au/forums/topic/285088-need-some-help/#findComment-4790795
Hey guys
thanks
Yes you will need to tap a new location for the tensioner, should be in the build pdf I think.
What are you doing with the bottom end? forging it or leaving it standard?
Standard, you're better off with the 25DE head for compression reasons. If you're forging the bottom end then get some twincam 30 specific pistons and use the 25DET head.
https://www.sau.com.au/forums/topic/285088-need-some-help/#findComment-4791496
thanks
Here is the PDF File
rb30_dohc.pdf
https://www.sau.com.au/forums/topic/285088-need-some-help/#findComment-4791574
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
