stripping complete r33 series 1 5 speed gtst
have all panels and lights
complete interior etc etc
some parts just off the top of my head
EXTERIOR
front gaurds
bonnet
boot with wing
m spec side skirts
doors complete with glass
rear bar
front lights
rear lights
all windows
rear wiper
front wipers
INTERIOR
rear seats
dash
dash cluster
dash facia
door cards
a/b piller plastics
back plastics
hood lining
rear view mirror
glove box
centre console
all pedals
UNDERCAR
front and rear hubs/knuckles/conrol arms/calipers/struts damper adjust (kyb i think)
3inch cat back exhaust
steering rack
engine cross member
located northern nsw/gold coast
pm me if interested in anything
thanks
https://www.sau.com.au/forums/topic/285505-wrecking-complete-33-gtst/
  • Replies 91
hey mate,
im buying a new 33 gts in the next little while, what the condition of the parts? can you PM me pics. just of the interior dash.
Cheers
not sure if ur asking if its aturbo model or if i have the turbo but yes yes
turbo had just been rebuilt when car was pulled off the road
has zero shaft play :) pretty much new
thanks
1side skirt white
1sidesjirt burgundy lol
will find out make of exhaust
$400 for just turbo
it was just rebuilt before being removed from car
has zero shaft play pretty much as new
i have stock series 1 and series 2 steering wheels
both are abit worn but
will check the lights to see condition but
dont have the rest sorry
thanks
Hi there, i will take the: RB25DET Crossmember, RB25DET Rubber Engine Mounts, RB25DET Alumunium Engine Mounts. Please let me know ASAP. Thanks. My Email: [email protected]
PM me a price on this stuff please:
rear calipers with brake lines to first conection,
rear backing plates,
and hand brake cable set up from both sides up to where it meets the conection and goes to one cable
also rotors if in good condition same with pads,
thanks, mike
thanks
Can you post/pm me a picture of the series 1 steering wheel? Is it the non-airbag one?
Also do you have the stock Boss kit thing?
Thanks.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
