Hey all ive done a r33 gtst brake conversion and now need to up grade my booster and master cylinder to cope with the new brakes
has any body done this if so what have you used ( out of what car)
cheers
Lachy
Why do you want to upgrade? I have been told my existing MC will cope with GTT brakes (haven't had time to fit them yet but I believe others have done it with no MC change).
I changed my brakes on a S2 to R33GTST calipers and I still use the original Master Cylinder. Car seems fine, it did seem slightly different initially e.g. slightly more travel but otherwise there fine.
Tried a brake stopper ?
Supposed to make a huge difference what with the bulkhead flexing a touch.
I'm getting mine made and fitted this afternoon.
I'll let you know how it works out.
Oh, And i also have some GTT brakes to fit too .. If the go under my wheels .
i tried re bleeding the brakes as i thought that might have been what was making the pedel feel spungy and long in travel , but it didnt make a difference.
i think i will try fitting a 33 boster and master cylinder as they are 33 brakes i am using
  • 4 weeks later...
Finally fitted my GTT rear brakes. Thanks to other people's "how tos" I bought some metal cutting blades for my angle grinder to cut the lip off the backing plate and pulled the nipple out of the inlet (although the banjo bolt was a fraction too long that way so cut a couple of threads off it). The main bolts were exactly the same as the stockers. The master cylinder is coping fine now but I'll see how it is when I get the fronts on. I am using the GTT 4 pot calipers but have brackets, to space them out for bigger rotors, which I am not sure goe with the GTT calipers so I'll see soon!
Hi
I have recently done the R33 upgrade on my S1. I did the front a while ago (calipers only) and everything worked fine except the peddle had a little more travel. Now I have put the rears on I thort that I would do the m/cylinder (that’s m/cylinder only $80.oo 2nd hand) at the same time. That’s because when you upgrade to bigger brakes they require more fluid to operate. The standard S1 m/cylinder is a BM50 and the R33 is a BM57 (1-3/16”) so now my peddle only travels about 25mm and has a very firm and positive feel to it.
I used one of these to cut the dust cover off it’s a punch so there is no sparks to worry about. $70.oo from Supercheap
Get one of these from Auto barn ($11.oo) and you can do the brake bleed yourself. It has a spring and ball in it so it holds the brake fluid in the clear tube so you can check for air. You pump the peddle five or six times check for air fill m/cylinder and go again if there is air in the tube
Hope this helps
Awesome thanks Phil. I don't know why but for some reason I always thought you had to pressure-bleed cars with ABS. Apparently not... = easier :D
Edited by DaveB
Good write up Phil. So you're saying the R33 (presumably turbo) has a bigger master cylinder than the S1 Stagea? We certainly have been short changed on a few components. Good to know it doesn't have to be a 34GTT mc but can be off a 33GTST.
I was told by the gent at the import wreckers that it was off an R33 so I can’t say whether it is the same as an R34 but it doesn’t really matter all we need is one with BM57 written on it and it will bolt straight up. As far as pressure bleeding goes if you bleed the m/cylinder first it should push all the air through to the wheels (I had the car on four stands on level ground weather that makes any difference). I did have someone give me a hand at the end (blister -turned up when the work was done lol) but there was no air in the system doing it the usual way with two people.
I am running EBC Green stuff all round (Front-DP21200 Rear-DP2826) I found they work really well although you have to watch your first brake application in really cold weather (firm peddle reduced braking till they get a little heat in them). They are very dusty for the first five hundred KL aprox but after that there is nothing to speak of.
I am very happy with how they work. We went on the SE stagea cruise 20.9.09 and I had four adults one child and an esky on some windy roads and it didn’t matter how often I used the brakes the feel was the same. :D
Now doing the fronts on my S1. I have a set of R34 calipers and rotors and they fit no problem - the bolts are the same just have to change the inlet on the caliper to use the banjo fitting. As it happens i saw a big brake kit after i bought the R34 stuff which gives me slightly bigger again rotors (324mm) but these are heat treated, as new, and slotted, whereas the R34 ones would have had to be skimmed and slotted, and there's a bracket which moves the R34 calipers out a touch. Brakes work fine but i have lined up a bigger m/c as above just to reduce the pedal travel.
One thing I did not mention was that I had to change the resoviour so the wiring would plug back in.
I held the m/c in the vice and used a file between the two to pop it off then it’s just a matter of putting yours back on
What m/c will you be using? Is the R34 m/c a BM57 as well?
Dunno but I imagine so. the one I bought off Trade me turned out to be a BM44 - my fault for not checking - so I am still on the look out for a BM57!
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
