  • Replies 165
Posted Images
Ok guys, date is set...
Friday 9th of October at 7:00PM. Coopers Ale House on the corner of Carrington and Pultney St.
Here's the list of attendees so far
1) Madaz +1
2) Heslo +1 or 2
3) dark.sky
4) typevu + 1
5) Aberax + 1?
6) wnted1 +1
7) BensDR30 +2?
8) Matty T +2
9) bucklup +2
10) mrRS4 +1
11) scandyflick
12) Krishy
13) sapphiregraphics
14) Damo_R34 +1
15) Brezza
16) 2FST4U.R33
17) Ripp3r
18) J_Red33
19) Dohmar
20) YOUWISH +1
21) RubyRS4 +1?
22) Luke_ENR34
23) DamageInc
Congrats Maz and Luke on your new positions!! :) I am sure you guys will do an excellent job! ;)
I think I will have to arrange a visit that will include coming along to a SAUSA Dinner in the coming months!!!
Coopers is pretty yummy food wise, but once again parking is shite..lol
who is roping off 20+ spots across the street from it...hahahahaha roadworks cones anyone ????
be a good photoshoot to line the lines up ????
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
