Hi guys n gals!
Thought I'd put a thread up of my nugget here!
Just a bit of a background....I had a 254rwkw R33 gtst for over 3 years, was just getting a bit costly for me to run at the track etc while Ive got a wedding coming up. So after 6 months of looking for a cheaper replacement, I found the mx5 up in QLD.
The car was built and logged as a CAMS 2F race car.
Can be eligable for FOSC, Prod Sports, MX5 challenge, etc
(I'll hopefully be doing MRA and MX5 challenge in 2010)
I havent done too much since buying it, but previous owner bought it stock standard and stripped it and caged it and log booked it!
He raced it for over a year up in QLD, but got into money issues and needed to sell. And I needed to buy :)
So...
Its a 1994 MX5 NA8 Clubman.
Mods when I bought it...
6 point cage
sparco drivers seat with 5 pt harness
daytona passenger seat with sparco 3 pt harness
TEIN Flex coil overs
Whiteline front sway bar
Some a/market caster and camber bushes etc
Brake master cylinder brace
stripped interior
CAMS approved tow hooks and kill switch
Braided brake and clutch lines
Toyo R888 semi's
A shot just after I bought it.
Got it engineered down here in NSW through Greg and Brad @ autosport engineering - big thumbs up there!!!!
Since I have owned it, I have added....
MX5Mania cold air induction - can see it in engine bay shot.
(s13deviats s13 in background!)
Full exhaust system,
4-2-1 extractors, high flow cat and 2.5" cat back exhaust
advanced timing from 10degrees to 14 degress.
Also added RDA slotted rotors with QFM A1RM pads
Just Jap shift light
So far times I have done...
Round 2 SSCC interclub supersprint March 8th - OP GP
1.30.4 - first in class 2B
Round 3 SSCC interclub supersprint May 17th - OP South
55.2 - first in class 2B
Round 4 - SSCC interclub supersprint June 7th - Wakefeild
1.15.1 - first in class 2B
Round 5 - didnt race as was flagging - Wakefield
Round 6 - SSCC interclub supersprint August 2nd - OP GP
1.27.2 - 1st in class - 2B
Round 7 - SSCC interclub sprint 13th september
54.2 - 1st in class
Round 8 - SSCC interclub sprint 18th October
2.00.4 - 1st in class
Car prob makes around 70-80rwkw! It has pretty good corner speed, just lacks straight line speed LOL
Plans for next year are cams and an ECU - can net upto 100rwkw - while its not MASSIVE power, it helps in a lighter car!
Anyhoo, a few pics from some track days,
While its not going to set any world records, its a fkn fun car to drive, and will teach me alot about driving @ the track, and set me up for later races and door to door!
Here is a vid from our SAU NSW OP GP day
Thanks for reading,
I'll update as I go :bunny:
Cheers,
Chris
very nice mate
  • Replies 188
Posted Images
Nar not a car trailer, I bought one about 12 months ago.
It is another car for a bloke, he has been coming to me for a while now getting bits and pieces done. I have a new engine on the stand to go in it vroom vroom, Then it will be the MX5's turn.
Show us ya knob hehe.
  • 3 weeks later...
yeah Im loving the black wheels!
I just need a black front lip and yay!
so july 11 is EC. first supersprint this year for me....
my goal is to get under 2mins - however I doubt it as I havent been behind the wheel at the track since december :(
  • 3 weeks later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
