Hi guys n gals!
Thought I'd put a thread up of my nugget here!
Just a bit of a background....I had a 254rwkw R33 gtst for over 3 years, was just getting a bit costly for me to run at the track etc while Ive got a wedding coming up. So after 6 months of looking for a cheaper replacement, I found the mx5 up in QLD.
The car was built and logged as a CAMS 2F race car.
Can be eligable for FOSC, Prod Sports, MX5 challenge, etc
(I'll hopefully be doing MRA and MX5 challenge in 2010)
I havent done too much since buying it, but previous owner bought it stock standard and stripped it and caged it and log booked it!
He raced it for over a year up in QLD, but got into money issues and needed to sell. And I needed to buy :)
So...
Its a 1994 MX5 NA8 Clubman.
Mods when I bought it...
6 point cage
sparco drivers seat with 5 pt harness
daytona passenger seat with sparco 3 pt harness
TEIN Flex coil overs
Whiteline front sway bar
Some a/market caster and camber bushes etc
Brake master cylinder brace
stripped interior
CAMS approved tow hooks and kill switch
Braided brake and clutch lines
Toyo R888 semi's
A shot just after I bought it.
Got it engineered down here in NSW through Greg and Brad @ autosport engineering - big thumbs up there!!!!
Since I have owned it, I have added....
MX5Mania cold air induction - can see it in engine bay shot.
(s13deviats s13 in background!)
Full exhaust system,
4-2-1 extractors, high flow cat and 2.5" cat back exhaust
advanced timing from 10degrees to 14 degress.
Also added RDA slotted rotors with QFM A1RM pads
Just Jap shift light
So far times I have done...
Round 2 SSCC interclub supersprint March 8th - OP GP
1.30.4 - first in class 2B
Round 3 SSCC interclub supersprint May 17th - OP South
55.2 - first in class 2B
Round 4 - SSCC interclub supersprint June 7th - Wakefeild
1.15.1 - first in class 2B
Round 5 - didnt race as was flagging - Wakefield
Round 6 - SSCC interclub supersprint August 2nd - OP GP
1.27.2 - 1st in class - 2B
Round 7 - SSCC interclub sprint 13th september
54.2 - 1st in class
Round 8 - SSCC interclub sprint 18th October
2.00.4 - 1st in class
Car prob makes around 70-80rwkw! It has pretty good corner speed, just lacks straight line speed LOL
Plans for next year are cams and an ECU - can net upto 100rwkw - while its not MASSIVE power, it helps in a lighter car!
Anyhoo, a few pics from some track days,
While its not going to set any world records, its a fkn fun car to drive, and will teach me alot about driving @ the track, and set me up for later races and door to door!
Here is a vid from our SAU NSW OP GP day
Thanks for reading,
I'll update as I go :bunny:
Cheers,
Chris
very nice mate
  • Replies 188
Posted Images
Nar not a car trailer, I bought one about 12 months ago.
It is another car for a bloke, he has been coming to me for a while now getting bits and pieces done. I have a new engine on the stand to go in it vroom vroom, Then it will be the MX5's turn.
Show us ya knob hehe.
  • 3 weeks later...
yeah Im loving the black wheels!
I just need a black front lip and yay!
so july 11 is EC. first supersprint this year for me....
my goal is to get under 2mins - however I doubt it as I havent been behind the wheel at the track since december :(
  • 3 weeks later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
