  • Replies 188
Posted Images
so...
I was hoping the oil press gauge would work straight off the existing wire...but it doesnt
the neg and pos wires were wired up and worked, but the actually pressure one wouldnt and would go straight past 7 on the gauge
doh!
any ideaS?
Chubbs, as Andrew said you NEED to use the sender that came with the gauge.
The sender in the car and the sender that came with the gauge will send out a different signal for the same pressure, hence your gauge going off the dial.
Swap senders, all perfect!
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
I hear that you and Ando are after a little more punch so I have found you an option on ebay - http://cgi.ebay.com.au/MX5-turbo-greddy-/170589445653?pt=AU_Car_Parts_Accessories&hash=item27b7ec5e15
You know you want to........
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
