How many times have you wanted to buy something when offered but the member does not say where they are and its not listed in profile. Would be a time saver if town/state info is listed. Maybe mandatory???
https://www.sau.com.au/forums/topic/285989-where-are-you/
... and yet you don't have it in your details under your avatar! :(
LOL!
I agree, it's so simple, either add them to your thread when you want something, or add it to your details in your profile so it's done once and for all, and you don't have to remember each time you post wanting something...
https://www.sau.com.au/forums/topic/285989-where-are-you/#findComment-4800923
yeah that shits me!
see some bargains, you show interest but not knowing where their from, and of course they dont reply for a week. then found out its in another state!
same with the stagea spotted section, im not good with street name's i just know how to get places. so a state atleast in your avatar would be handy to cancel out confusion.
bloody tools!
https://www.sau.com.au/forums/topic/285989-where-are-you/#findComment-4801493
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
