hey guys and gals..
im booking a private grip day for monday 26 of October.
20 spots avail.
the total cost of the day is $3700
so work it out that if we get 20 ppl it will be $185 each..
so the less the more it will be..
now i will find out tomorrow when and if we need deposits by and ill re-confirm this with you..
1. rad32 (Adrian)
2. Damor34 (Damien)
3. HVN032 (Scott)
any questions please let me know and ill endevour to answer..
cheers,
Adrian
https://www.sau.com.au/forums/topic/286079-private-track-day/
  • Replies 650
I would but i've got the time attack at the start of October and i can do a normal grip prac day for $100 so its not really worth it. If it was drift i would have been keen to give it a go.
I'm there, put me down for a spot for sure.
At mallala I assume!? unless you sprung a new track up somewhere :blink:
How much track time are we talking? My boss books out the track reguarly and they get the whole day just to their attendees so I assume this will be similar?
I'm keen but had to hand my car over to another crash repairer to get quotes to fix the first repair. Not sure if I'll have the GTR back by then. I could take the Pug 205 GTI and race against HELSLO but the little turbo would probably have me.
hell slow
hahah
nice 1
-D
:D Not what you think Ben, the plates HELSLO are actually on my mates turbo Starlet, I think that's what David was referring to
So what do urs mean dude? :D
He Slo (He slo)
Hes lo (He's Lo)
Heslo (Heslowpokensonofbitchenvontyrespinnendasmitubermenschen)
-D
Long story but it comes from a grandmother of one of my friends... inside joke really
dammit you just gave me a soft on
now i cant taunt you, for taunting over grandmother nicknames is unforgivable
I fart in yr general direction! je'accus!
-D
ola jose
put me down for this one mate....for $185 wont mind trying out a few things....will ask around might get my mate with his s13 coming as well....so who is also going to the 23rd november track day???
ill def be at the nov 23 day. gonna try and make this one. but we'll see. gotta buy an oil cooler and some new pads. lol.
some dude at work with a 5 series beemer (auto) is keen, hilarity will follow.
Edited by scandyflick
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
