Going through my window cam and working it out by the footage, the fastest times I did were 1:27's (many times), averaged 1:28 if I wasn't caught behind someone. What kinda timers are everyone using?
My 2nd off about 1minute after my dirt bath:
and my corner exit onto pit straight tank slapper:
youtube links should be right now
Thanks for the links, I was in the stocky white 33 in the vid.
Thanks to Adrian for organising a great day out, enjoyed by everyone there I'm sure....
  • Replies 650
I was the photographer out there for the morning(other commitments meant i couldent do the afternoon)
i will post some pics up here soon, was some very nice cars (was also my blue 32 in the pits incase anyone was wondering!)
cheers jamie
Jamie, were you on corner 2 just near the pit straight and then on the final corner near the start / finish line ?
last time it was dyno'd it was 170. added a couple small things since then, and the boost is a little higher (1.2 bar now, was 1.0), need to fit my ebc and adjust the timing a little bit.
fantastic day ! cheers again adrian and everyone out there.
my front pads are allllll metal, flakes and pins of metal and not an ounce of pad ! - slotted discs will be ok and fine tho.
ordered new pads as its hard to find db1250 over the counter
doing oil service right atm, ready for new pads to be dropped in tomorrow/thursday whenever delivered.
also found where the fuel map stops at 6000 - 6400rpm. needs a recalibration via a full license nistune/consult (mine cant change the logs)
Anyone who was having problems with their pads running the QFM pads.
I have done 3 track days with the set on the 180 and they (the fronts) still have at least another day left in them and the rears are bearly touched, that's pulling 1:23's as well.
Edited by D_Stirls
cant say enough about my qfm pads. they were brilliant. only lost the pedal twice during the day, and i daresay that would have a fair bit to do with my rears f**king out repeatedly.
Here is some in car from No.96
I was meant to warm up my tyres for a lap and a half and then push on. It is amazing how an R35 going past changes plans.
I use my mobile phone to video, it is mounted next to the rear view mirror, as I got to the Southern Hair pin the phone rang and stopped videoing.
enjoy
What my brand new front QFM A1RM pads looked like after the 4th 20minute session (I only knew something was up because i heard scraping on the left front while pulling out of pits into general area.
I've done 2 track days, motorkhana and a number of spirited drives on my qfm a1rm pads and rda slotted rotors all round and theyre only about half worn.
i averaged on 1.30 at mallala on shitty street tyres and running 10psi (anyhting over computer has a fit). Minimal brake fade after 6-7 laps.
Theyre great value for money, and i will be getting another set once these are goneski.
Might also depend on the way you drive i guess, some people i know chew through pads and rotors no matter what they are.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
