(and MILES better than EBC Red :blush:)
I'm just wondering how the QFM pads could be MILES better... I'm didn't experience brake fade once and I was pushing that brake pedal pretty damn hard lap after lap. If QFM are at least as good or better I'll happily buy a set when I'm due next, just honestly wondering how much better they could be.
  • Replies 650
I saw heaps of people snapping pics on the day, anyone got more to post?
Pat's S14, a sedate V35, and it's fire breathing cousin the R35:
random people in the crowd:
end of the day with people changing their brakes in the garages:
Edited by V35-2005
C'mon photographers & happy snappers. There are only 14 photos so far in this thread since the track day (not including the brake photos from Chad, Dave & Lance). There were 20 cars out there!
I expect more images by midnight Sunday night or else I will put a formal request to the mods & SAU-SA executive committee that the photographers be given a warning and banned for a month :happy:
Looks like I'm getting some body roll in the pictures while im turning into corners, think it's worth upgrading from the factory swaybars to cusco/whiteline ones?
Some? :down:
What suspension? Standard? Looks it, if so I'd be tackling that first
Nismo S-Tune coilovers left on medium damper setting, would have changed to hardest setting but I don't have the tool to easily change the rears.. need to take boot trim apart to attack it with pliers
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
