What a night at WSID. My spark plugs gave up the ghost pretty much at the beginning of the night, meaning the car was missing quite a bit down the strip. Combine that with some novice launches early on and its fair to say I had some challenges to overcome. But a 10.8 pass at 127 mph with the car still missing badly was a great return for the night.
reaction time .295
60 foot 1.712
Next steps are new spark plugs, injectors and the full Cobb tune. Then we'll be in business!
https://www.sau.com.au/forums/topic/286343-adm-r35-does-108-127mph/
Paul,
Congrats on the great time considering there is heaps more to come out of the car.
Spark plug issue was a minor distraction with a few light misfires at maximum torque only.
This was mainly due to the fact that the car had been previously circuit raced for a full day,
which wears the plugs out prematurely, especially at the power level the cars at.
A fresh set of plugs are on their way as are other goodies for your car.
10.8 @ 127mph has got to be some sort of record for an R35 GTR in Oz?
Does anybody know if any other R35's have run a 10 & if so who?
Congrats on the time, are you now banned from the track, are you going back?
Last week i ran 11.1@125mph (at WSID) mods were mid pipe and AP tune (everything else stock, inculding wheels and tyres - bridgestones).
I might go out next week with some better/lighter wheels and tyres to see if i can get a "10"..
Thanks Duncan, I was politely asked to leave the premises after that run. I will certainly be back. I suspect there is a low ten in this car with bigger injectors, fresh spark plugs, and full tune.
There was no wheel spin to speak of, just a short chirp when I nailed the launch.
Let me know when you are going out - I might tag along.
Cheers
Paul
Cheers
Paul
Paul, are you putting a cage in it?
Cheers
Paul
Well done, mate.
Why did they ask you to leave?
Well done, mate.
If you crack a sub 11 second pass you have to go and put cages and stuff in your car. That regulation must assume that a ten second car is capable of leaving its lane...reality is this thing could probably crack a nine second pass and hardly spin the wheels.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
