Sau Nsw Oran Park South Track Driver Training Day
Anna's car doesn't rip epic skids...
No, I don't think this pic is old quite yet :(
lol.. I absolutely love that shot of my car!! I need it made into a signature!!
Alrighty I have just paid for one entry (my bank is weird so might take a couple of days to come through), il have to wait a couple of days to see if Dave can enter too... but more than likely he will. Both be in my line, so different groups please
NO idea which group as its been a while... will be on semis not slicks though ... I ran a 54 in the 200ZR last time out on south but that car was so busted with no brakes!! Pop me into whatever group, Im probably slower these days :) .... Dave hasn't driven OP at all (I am surprised!) but I am sure he will be faster than me but maybe not at first!!
  • Replies 389
Posted Images
how's the first timer group looking?, I'm 50/50 right now on attending :(
I'm gonna need new tyres soon so hey, maybe get them replaced before the event?
brake pads/fluid
anything else I need to consider?
hey yoyo, unless the tyres are rooted just hold on. they will be even rooteder after the day, and you dont want to smash a brand new set of road tyres on the track.
most people who have been bitted by the bug end up buying seperate rims because semi-slick tyres last longer, are cheaper (per day) and perform much better.
definately bleed the brakes with good fluid like motul rbf600 (or get someone to do it), and replace the pads if they are under 50%, you will put plenty of wear on them if you are giving it a bit (and judging by how you drove at texi I think you will....)
thanks for the advice duncan, believe me it's not a case of not sure about attending, I'll be the first one there lol just I REALLY should be spending this money on my house deposit :D on the other hand, it's gonna be my first and last chance for OP so why not?
my brake pads are still good, just probably want to replace them afterwards for peace of mind is all
tyres...my fronts are almost gone, i'd say 50% tread on outside edge for my fronts, will that pass for the day? rear tyres are still good
other than that my swaybars and springs are on and my exhaust will arrive before then, all I can say is I wish they came before texi :)
how's the first timer group looking?, I'm 50/50 right now on attending :)
brake pads/fluid
I've been doing some research on preparation for club events. Here is a "check list" I found from the BMW Club of Qld. Looks pretty good.
Track_Day_Checklist_Ed1.pdf
cheers eric
fark it count me in I guess, depends on a few things...
I'll take pics of my front tyres and you can tell me if I can run them for the day, cause believe me once you see them they're not gonna last for much longer after that
so my plan is to run out what's left of the stock tyres on the day then just get the tyres replaced after that...
so not looking to set any competitive times, just enjoy the track before it closes and have some fun :D
plus I have some leather driving shoes that I can use, but I doubt they are fireproof, will they be okay?
that's a good checklist.
if my cars not ready by then i wil come and do some recording :(
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
