My 1st Time @ Winton Drift Experience
so, can i just go drift in any beat up rwd car dents and all? doesn't need to be registered does it?
And i understand i need a CAMS license or something, right?
yep. just gotta pass scrutineering (no oil leaks / car must be safe) and get CAMS or AASA licence.
nah, deans's not a member dude....
lol sorry? Whats that got to do with it? I didnt see ya there Hamish, you shoulda come. Our 33's woulda looked good crossed up together :P
Anyway, as per the below pics, yes that was my 33. The car felt absolutely fantastic, didnt surprise me all day and it took 3rd gear all day with no hesitation. Youtube in-cam vids will be up soon...
i was there also black r32 grey bonnet, was a madd day heaps of cars, car handled really well, will be at the next one for sure, how did you guys go with ya oil temp? my water was madd kept cool all day.
redr 33 was maddd you got screammer?? or external gate??
Wow nice pics guys. Drifting always looks like so much fun! Cant wait to get out there!
Russ well get stuck into the car as soon as I finish uni I reckon. Ill just work on it every day at the workshop to get it done! But in the meantime if we can get the deadener off and material for the cage that would help.
In-car vids anyone?
Its a 'just jap' screamer. Running a HKS 25/40, internal gate...
Femno, ill have some good in cam footage up by early next week... :)
lol sorry? Whats that got to do with it? I didnt see ya there Hamish, you shoulda come. Our 33's woulda looked good crossed up together :)
i'll probably be at the next one of the car's ready in time mate... but it will be the ke70 not the 33 :)
got any pics that show the new wheels from closer? they look nice from a dist...
Geraus, what number were you? Tried running a search on my site for you car number? If still no, i'll have a quick look through my shots and see if i might have skiped over them.
Joey, here's an up close shot :bunny:
and a few more for fun.
Ha. I didn't even realise that silhouette was of my car! It looks to neat and straight in the dim light, lol. That's an exceptional shot Jarrod, cheers.
Edited by White GTS-T
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
