less restriction from the exhaust,
what car and what mods do u have??
i have a 95 R33 not much done is pretty much the same as when i bought it bigger turbo i think its a t3 with a t4 exhaust, full 3inch exhaust front mount hks air filter. i should be getting a fair amount of money soon to spend on the car. im going to get a computer im thinking a power fc or microtek i havent decided yet and im going to get a g35 turboi think it was called and a plazzma man Plenum. im basicly copying a friend of mines engine and i wanna do similar mods to him my plan is to basicly keep bolting things on untill im happy with the perfomance then get the internals done. my mate also has a screamer pipe it sounds cool enough i think it would get annoying on an everyday car thou i was just wondering if it made any power differnce
if you have a large external gate turbo it may help performance, it will also be very loud and a large defect.
if you have an internal gate turbo it would sound like crap and still get you a large defect.
im not sure about that i think its internal. i will be honest i dont really know alot about cars yet... im defenatly interested its just my work takes alot of my free time do you guys suggest any particular mods as a must have?
Edited by R33Gtst Driver
https://www.sau.com.au/forums/topic/286912-screamer-pipe/#findComment-4813808
MUST HAVE:
1x FKING LOUD ALARM.
1x Immobiliser.
1x Insurance for when someone attempts to steal it.
That should get you started.
+ 1
no good if all the go fast bits make the theif escape faster lol
https://www.sau.com.au/forums/topic/286912-screamer-pipe/#findComment-4813930
lol soo true
yeah i got a immobilzer (it came with it) but the siren is cactus it was on my todo list but yeah that should be at the top any recommendations? on brand? i kinda had alook a few months ago but there was so many features and brands that i just left it
https://www.sau.com.au/forums/topic/286912-screamer-pipe/#findComment-4814098
I've got a mongoose of some description, came with the car when I got it haha
I haven't as yet set the alarm off and let it get past the warning stage (which mind you will still turn plenty of heads if it's set off in public)....will really have to give it a shot lol
I too am considering the GPS tracker, though with so many things on my to do list, it's not really at the top...especially when I've just paid for airfares and accommodation deposit for a trip to Utah beginning of next year :(
https://www.sau.com.au/forums/topic/286912-screamer-pipe/#findComment-4814182
the only thing you will gain from a screamer pipe is a shit load of noise and defects if cops hear you on boost.
the don't restrict the exhaust and if they do we're talking about 1hp or less.
Many supra's with big singles still run it plumbed in. Not worth the defect!
https://www.sau.com.au/forums/topic/286912-screamer-pipe/#findComment-4814569
Look on the bright side.........when your car gets defected and you have to take it across the pits............when you finally loose the last points on your license...............you'll have plenty of time to rebuild that motor!!!
https://www.sau.com.au/forums/topic/286912-screamer-pipe/#findComment-4815193
Im not normally rude (lmao) but spend the money on your GF
or even better buy HKS SSQV BOV/s.
Better sound IMHO
Oh and Kat dont poo poo the Poopra's :P I have one of those too!
S!N
Edited by Sinista32
https://www.sau.com.au/forums/topic/286912-screamer-pipe/#findComment-4817314
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
