Hi fellas,
I tried searching but cannot find anything. I need your help. A few days ago, some short-circuit thing occurred in my R33 and my power to my stereo and clock just turned off. I am betting my marbles that it's a fuse issue and that they need to be replaced - does this sound right?
I recently bought a translated fuse box instruction slip in English so I know what's what now. However, I don't seem to know how to remove the fuses. I've tried pushing them in hoping they'll bounce out and also tried forcefully removing them but cannot. Can someone please give me more specific instructions? Also, should I just purchase 10 amp fuses from Autobarn and replace ONLY the fuse for the stereo or any other as the clock has also gone?
Many thanks.
Kevin
https://www.sau.com.au/forums/topic/287161-how-to-change-fuse-in-r33-skyline/
r33's have a small black gripper thing you can use to remove the fuses. its located on the left? side of the fuse box i think. but its not that great.
get a pair of long nose pliers to grab the fuse and pull it out. thats the best way.
and as far as replacing with 10A. Just use the correctly rated fuse for each spot.
Check each fuse as you go, replacing any that are blown.
fairly simple stuff.
edit: beat me to it :P
Edited by Munkyb0y
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
