  • Replies 112
You want to buld a 400rwkw car on a tight budget? :(
Unfortunately money does almost need to grow on some tree's if you want to build such a setup...
As you have seen buying a cheap I/C core could well be your issue here... could be something else, that's the fun of a 400rwkw setup - it takes time AND money.
Where are you referring to ?
There is more than one company in the land of Oz that makes I/C cores you know... :huh:
  • 1 year later...
Long ur for a update but here it is
Intercooler pressure drop - <2psi
Exhaust back pressure = < 1psi to redline on load
ValveSprings replaced with brand new ones
Seems like all was fine however we found that the cas does need to be replaced. The timing and injectors are a bit off and after a stab of the throttle there is misfiring.
Thoughts?
Will check back when that's done. Any advice in the meantime will be great.
Edited by Jap_Muscle
Told you there was setup issues mate.
Glad to hear you finally got around to sorting it out, rather simple in the end :thumbsup:
its a great feeling after its all been resolved. it be good to see what we can do with e85 now.
what was the issue the cas was doing?
From what i understand, the back of the cas was actually being stripped away by something. The actual thread was completely gone. My mech said it possibly could have been due to the fact that the old cas didnt have any spacers. Because of this it was giving incorrect readings to the cam timing which caused all types of dramas.
hope that helps.
Im pretty sure It gets stripped away by the 4 bolts holding the camgear on. If you bolt up the cas with no timing case it doesnt have enough clearance. I think from memory its around the 3-3.5mm mark it needs to be spaced out.
Good to know mate, ill remmember this if it ever comes up again.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
