on the main part of the forums page at the bottom is the most recent replied to posts could u by any chance put that at the top its very helpful wen u dont feel like scrolling down :)
That part used to be on the main page there were like 10 more recent
something easy like that would b good for ppl in a rush so u can just see most recent then close the rest
Thanks mate!! GOOD JOB !!
I like the new colour scheme and layout, BUT where can I find the link for the galleries and where is how many posts each user has, listed under the avatar?
I think I must be going blind.
Guest RedLineGTR
Members List in the top menu u can find all memebers and post counts for people. The Galleries (http://www.skylinesaustralia.com/gallery/) is still there but not in the menu atm because a new gallery will be "installed" will look better and more user friendly :D
great another version to work on... lol is this gonna be the last upgrade... PranK hook me up with this release so I can make the styles for it.
Sory I haven't had any progress,just finished moving houses.
