Hi there everyone,
There seems to be emails going around and it has been word on the street that Aaron Diebert has been stealing high performance cars of late and dumping them around Canberra... Well as much as some people would like to believe its him i can safely say he's locked up at the moment and has been for the the last four months... He was only at for two weeks and at that time he had spent 14 months in jail. So people shouldnt mention ppls names without knowing facts it could cause alot of trouble... Oh and by the way the person trying to describe Aaron's work honestly has no idea, so as much as he'd like to think he's some kinda Maxwell Smart solving crime... Your way of mate so maybe you should follow some other leads :D
https://www.sau.com.au/forums/topic/287294-misleadin-information/
whats he in jail for?
yeah it was posted some where else but i'm not a member... He's in there for stealing cars i think.. I didnt post that to stand up for him anyway, i just thought it was funny that some one thought they had it all figured out n really they aint even close!!! That;ll teach him for putting ppl's names on web sites...
haha if you're not sticking up for him, watch how you word things. That last post almost sounded like bragging, hinting it's yourself doing the dirty :D
But yeah I mean, if he's in gaol for stealing cars, then cars start getting stolen again, those who aren't aware of his current confinement are naturally going to point fingers in the hope of finding a resolution.
So you join this forum (that has mentioned nothing about this aaron individual), to tell us that this aaron scumbag is not responsible for the current car stealing. You make reference to posts that are not on this forum and expect us to understand them, then have a go at someone not on this forum.
If I could give you a tip, get better friends, and be kind to your mother.
I received an email in relation to this person and there was another 2 people invloved with this guy, one of which was female. Is Kerry the female I wonder ??? I did ask around and the people invloved are well known to the Police, so from what I've read so far, one person has been caught and there are still at least 2 other people that are on the Police radar.
Fingers crossed they catch them and we can all feel a little safer that our cars will not be stolen...
Why would you want to steal a sub $20K car anyway, better off with a Merc or Porsche etc, even a new commonwhore or such is worth more than most of ours - even when we heavily modify, its still worth jack sh1t compared to new cars!!!
No brains if your stealing 10-20 year old tokyo taxi's.
Generally speaking, those with the level of gray matter required to realise this also realise that stealing cars in the first place is retarded.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
