Hi all,
the Wife generously came to pick me up from the station last night and when we got ready to head home tadaaaa... nothing....
All lights work, connections checked and cleaned, jump started, disconnected the ECU and re-connected, checked all connections to SAFC, banged the alternator, check fuses in engine bay and inside......
turn the key and accessories light up normally but there is no clicking over..... like there’s no power to the starter or something.... checked that too.
I’m completely stumped....
the car has been driving perfectly for ages and just yesterday my wife drive it on many short distance trips without issues....
this happened once before when I initially installed the SAFC and SITC but then when the ecu was disconnected and reconnected it was fine ....
it sux as its our only car ATM.......
any thoughts or other checks i can do???
thanks in advance
Ian
https://www.sau.com.au/forums/topic/287337-s1-not-starting-at-all/
you say you bashed the alternator, did you think to tap the starter motor??
can you hear a 'click' when you turn the key?? if not, its probably the solenoid on the starter. if you can, its more than likely the starter itself........
actually thats a good point! if it WAS automatic, and its now manual (for whatever reason) then the starter inhibitor might be faulty. as in the wire bridging what used to be a switch, is now not working
Thanks for the reply... probably should have mentioned that i did hit the starter.....Not had :)
there is no click when the key is turned.....
long shot but in knocked off the solinoid wire to my starter motor.. same symtoms as u said... check that, is there any way to test if its getting power easy???
it was all in place but i have to admit i probably could have paid more attention to that... will do so tonight.
i just dont get how it just died after been turned off for less than 10 minutes.....
maybe try using a jumper lead from the positive battery terminal to the positive terminal of the starter, see if it kicks over.......
if you can hear a click, its either a wiring issue, or your starter is shagged. and yes they can just stop working!
Unless you have a quality surge protector fitted, I would not recommend doing this one. I have seen the ECU in a commonwhore go up in smoke trying this jobbie. Not saying it WILL happen, but there is a risk.
Make sure it is not in "D"rive when you turn the key?
Double checked that.
i had though about it but wasnt game enough
Damn: the flux capacitor requires 1.21GW of power to function... just get some plutonium...
...Or fit a Mr. Fusion
LOL
well i got it started....
didnt do anything really.... jiggled the loom at ecu and gave the starter another tap....
drove it and got back home switched the car off turned it back on and let it run for a bit and then off again....
then suprise it wouldnt start again..... did exactly what i did before (loom and starter) nothing
F*$K
My R31 did something very similar.
Would start when cold, but would not when warm (just after a drive or in the warmer months).
I used to get it started by shorting out the starter motor with a long screwdriver.
Worked every time.
My old R31 used to do this randomly, (had the hitachi starter not the bosch) turned out when I stripped the starter, one brush (out of four) was worn more than the others, and would occasionally juuust not be in contact with the comm.
Would start perfectly 50 times, then not, start perfectly for ages then not. Was a major pain, couldn't let my g/f drive it cos it might strand her. Four new brushes (I just took the brush holder to an auto elec, as the leads are soldered in place, didn't have a big enough soldering iron) $45 later, problem solved.
Chased this issue for at least 4 months, was ready to burn it... Good luck.
Well i have been doing the screwdriver thing all weekend..... so its definately starter solenoid.
Some random dude helped out the wife on friday and say it was "the starter solenoid valve".
Same boat
so anyone had to relpace a solenoid before??? same as R33 i would assume??
hard to get at your local supercrap or repco??
Apologies for the questions above… was a bit lazy should have assumed the starter was the same across the RB series.
Well yesterday I though id attack the starter and try to fix the solenoid…. One of the most traumatic experiences ever….
Man it’s a pain to even get the starter off….
Anyway I got the solenoid off and have all contact points a clean and re-soldered it…. Took about 2.5 hours to get it back on but it works now…..
Haven’t had an issue yet …… let’s hope it stays that way
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
    • Hey guys,  Way back when (about 15yrs plus), I picked up a beautiful set of Tein 'Super Racing Spec Circuit Master RE' coilovers from Russman. I have legit never fitted them to my car, as it was garaged indefinitely while i bought a house Yada Yada. They look brand new! Anyway its time to pick up where I left off, and have started doing some khanacross and am booked in for a hill climb next month. The car has some hard af Nismo shocks in ATM, which has me wanting to upgrade again, and now I am left wondering if it's worth having these teins rebuilt? I think they where an ok shock back then, but how do they compare to what's on the market now?  Shockworks/mca are 2800+, and I am sure they are great. But if I can have these rebuilt and be better than, say, a set of bc's for around the cost of bc's, I would be happy with the performance v cost trade off.  If they are considered outdated and rubbish these days, so be it, I'll put them on the shelf and be happy to look at the pretty green colour while I save for the SW/MCA option. Grateful for your thoughts on the matter, and suggestions on who could do the rebuild if it's a worthwhile pursuit.  cheers, Rowdy.
