Hi all,
the Wife generously came to pick me up from the station last night and when we got ready to head home tadaaaa... nothing....
All lights work, connections checked and cleaned, jump started, disconnected the ECU and re-connected, checked all connections to SAFC, banged the alternator, check fuses in engine bay and inside......
turn the key and accessories light up normally but there is no clicking over..... like there’s no power to the starter or something.... checked that too.
I’m completely stumped....
the car has been driving perfectly for ages and just yesterday my wife drive it on many short distance trips without issues....
this happened once before when I initially installed the SAFC and SITC but then when the ecu was disconnected and reconnected it was fine ....
it sux as its our only car ATM.......
any thoughts or other checks i can do???
thanks in advance
Ian
https://www.sau.com.au/forums/topic/287337-s1-not-starting-at-all/
you say you bashed the alternator, did you think to tap the starter motor??
can you hear a 'click' when you turn the key?? if not, its probably the solenoid on the starter. if you can, its more than likely the starter itself........
actually thats a good point! if it WAS automatic, and its now manual (for whatever reason) then the starter inhibitor might be faulty. as in the wire bridging what used to be a switch, is now not working
Thanks for the reply... probably should have mentioned that i did hit the starter.....Not had :)
there is no click when the key is turned.....
long shot but in knocked off the solinoid wire to my starter motor.. same symtoms as u said... check that, is there any way to test if its getting power easy???
it was all in place but i have to admit i probably could have paid more attention to that... will do so tonight.
i just dont get how it just died after been turned off for less than 10 minutes.....
maybe try using a jumper lead from the positive battery terminal to the positive terminal of the starter, see if it kicks over.......
if you can hear a click, its either a wiring issue, or your starter is shagged. and yes they can just stop working!
Unless you have a quality surge protector fitted, I would not recommend doing this one. I have seen the ECU in a commonwhore go up in smoke trying this jobbie. Not saying it WILL happen, but there is a risk.
Make sure it is not in "D"rive when you turn the key?
Double checked that.
i had though about it but wasnt game enough
Damn: the flux capacitor requires 1.21GW of power to function... just get some plutonium...
...Or fit a Mr. Fusion
LOL
well i got it started....
didnt do anything really.... jiggled the loom at ecu and gave the starter another tap....
drove it and got back home switched the car off turned it back on and let it run for a bit and then off again....
then suprise it wouldnt start again..... did exactly what i did before (loom and starter) nothing
F*$K
My R31 did something very similar.
Would start when cold, but would not when warm (just after a drive or in the warmer months).
I used to get it started by shorting out the starter motor with a long screwdriver.
Worked every time.
My old R31 used to do this randomly, (had the hitachi starter not the bosch) turned out when I stripped the starter, one brush (out of four) was worn more than the others, and would occasionally juuust not be in contact with the comm.
Would start perfectly 50 times, then not, start perfectly for ages then not. Was a major pain, couldn't let my g/f drive it cos it might strand her. Four new brushes (I just took the brush holder to an auto elec, as the leads are soldered in place, didn't have a big enough soldering iron) $45 later, problem solved.
Chased this issue for at least 4 months, was ready to burn it... Good luck.
Well i have been doing the screwdriver thing all weekend..... so its definately starter solenoid.
Some random dude helped out the wife on friday and say it was "the starter solenoid valve".
Same boat
so anyone had to relpace a solenoid before??? same as R33 i would assume??
hard to get at your local supercrap or repco??
Apologies for the questions above… was a bit lazy should have assumed the starter was the same across the RB series.
Well yesterday I though id attack the starter and try to fix the solenoid…. One of the most traumatic experiences ever….
Man it’s a pain to even get the starter off….
Anyway I got the solenoid off and have all contact points a clean and re-soldered it…. Took about 2.5 hours to get it back on but it works now…..
Haven’t had an issue yet …… let’s hope it stays that way
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
